Author Topic: Spax suspension,  (Read 2574 times)
Offline beechymonza
  • mad beech
Spax suspension,
« on: 21 January 2011, 19:47 »
I bought some spax suspension of ebay, There is a little screw on rear suspension, What is it for and what settin is best for just normal every day driving,, :cool:
No guts No glory,
Offline Sam
  • Sam I am
Re: Spax suspension,
« Reply #1 on: 21 January 2011, 20:18 »
Assuming that its the adjustable dampening screw your talking about it should have either 22 or 24 (cant remember exactly but look up spec on spax website) points of adjustment.
Screw it all the way to super soft then count ten clicks, should now be 'normal'. Then simply push down your car i.e sit in boot or push on wings and adjust acordingly to your taste, you will know when it feels right for you, mine feels firm and I think its on either 13 or 14 but can get a little rough. I also run my rear harder than the front, no idea why... just do lol. Just make sure you put both side to the same level though and take her for a long ish run before adjusting so you know exactly how you want to adjust (unless its stupidly obvious)
Also if your fronts will need one of these to adjust with in theory (or a spanner lol) and you do it on the top mounts, it makes sense when you look
« Last Edit: 21 January 2011, 20:22 by caistor_bmx »
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #2 on: 21 January 2011, 20:38 »
thats a good rule of thumb for adjusting  :smiley:
Offline beechymonza
  • mad beech
« Reply #3 on: 21 January 2011, 20:46 »
On the rears there is just a flat headed screw and underneath that a bigger flat headed screw, With a sticker above saying kryptonite , cant see anythin on the front  :huh:
No guts No glory,
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #4 on: 21 January 2011, 20:49 »
maybe they two different models ?
Offline The Mighty Elvi
  • I'm better than you today.
« Reply #5 on: 21 January 2011, 20:52 »
Take a pic and post it up.
Offline beechymonza
  • mad beech
« Reply #6 on: 21 January 2011, 21:07 »
They are not fully it just says rears have adjustable stiffness,
No guts No glory,
Offline dan_apps
  • too low for british roads!
« Reply #7 on: 22 January 2011, 09:59 »
rebound adjustment? ... what model are they?
« Reply #8 on: 22 January 2011, 21:27 »
If in doubt set in the middle and go from there.  :smiley:
Offline beechymonza
  • mad beech
« Reply #9 on: 22 January 2011, 22:12 »
To be honest i never realised the rears made much difference, I just presumed the fronts were the important ones,
What is the big difference that they can make,  :smiley:
No guts No glory,
