Author Topic: What gearbox fits on an 8v gti?  (Read 1324 times)
Offline ramps
« on: 21 January 2011, 19:46 »
I know there is a million different codes for them but does anyone know what codes fit on an 8v? Does a 16v one fit? a mk3 box? mk1?
Also, does a 020 box fit?
« Last Edit: 21 January 2011, 20:09 by ramps »
Offline tech1889
  • Mk2 GTI FTW !!
Re: What gearbox fits on an 8v gti?
« Reply #1 on: 21 January 2011, 20:49 »
an ABF box fits
Offline The Mighty Elvi
  • I'm better than you today.
« Reply #2 on: 21 January 2011, 20:53 »
Most do. Just have different ratios depending on the engine.
« Reply #3 on: 21 January 2011, 23:24 »
You will need to change the clutch to fit a 16v box.
« Reply #4 on: 24 January 2011, 09:44 »
any 1.6-1.8 8v and 16v mk2 and 1.8-2.0 8v mk3 box will be a direct fit, as will most 1.5-1.8 mk1/cabby/scirocco.  main worry is some boxes have 90mm shafts, and the really early MK1 boxes dont have holes for the mk2 gearbox mount.
MK2 16v and MK3 2.0 8v will only fit if you change the friction disc for a MK2 16v one as input shaft splines are bigger, but check the box code before you buy the clutch rather than take sellers word for it.
MK3 ABF 16v box will need clutch swap + cable shifter, and either hydro clutch or seat abf/tdi hydro->cable conversion kit.
