Author Topic: Fault codes after RNS and Bluetooth upgrade on MK6 - HELP!!  (Read 24219 times)
Offline branchespark
Re: Fault codes after RNS and Bluetooth upgrade on MK6 - HELP!!
« Reply #10 on: 30 January 2011, 15:52 »
Great idea. I'll do the same!
How do these things filter back to RossTech? Is there any info I can give them, do you think?
Mk6 GTD 5dr | Manual | Deep Pearl Black | 18" Vancouvers | Leather | Xenons | RNS510* + VW Premium Bluetooth (iPhone4) + Dynaudio | Smoked LED tails | Cruise
Offline Wabbit
« Reply #11 on: 05 February 2011, 20:53 »
I have just installed a late edition VW Bluetooth module but i keep getting an open circuit fault on the microphone.
Can i use the voice commands with a RCD510?
When i push the mic button on steering wheel it asks for the command but nothing happens when i say command.
Hope you can give advice thanks
Golf GTD MK6 Zenons, Leather, Dynamic Chasis Control, Park Assist, RNS510. Golf GTi Mk6 DSG, Leather. Golf Mk2 G60 Edition One, Recaro's, e/w, c/l, ABS
Offline Jimble
« Reply #12 on: 05 February 2011, 20:57 »
Darren had the same problem when installing mine, some thing to do with joining the mic cable instead of it going into the connector block as the loom was for an RNS, he made a loom up for me bless him and fitted it for me. sorry it's a bit vague because i have no clue about these things.
Send Darren (mortygt140) a pm and he'll sort you out. :wink:
Does the mic work at all when making calls? mine didn't.
Offline Wabbit
« Reply #13 on: 05 February 2011, 21:54 »
Jimble thanks for reply.
I have sorted it, i had it plugged in the wrong place. :laugh:
Offline Jimble
« Reply #14 on: 05 February 2011, 21:56 »
Ha, great stuff mate glad it's sorted, great piece of kit! :cool:
Offline Carrera-GTI
« Reply #15 on: 11 April 2011, 21:42 »
On the telephone coding you need to set the baseplate to inactive. The control module not coded will clear after this is set.
The output audio chanel one is because your loom is not wired for left and right.
The RNS error is because you have voice control enabled and don't have the mic routed via the RNS (again as issue in using the original factory loom).
Hello SteveP and other members, I really hope you can assist me, I have a 08/2008 Golf mk5 with factory fitted:
RNS510
DSG
Multifunction steering wheel and paddles for the DSG
Telepephone cradle AND
Bluetooth module (basic version: 1K8 035 730) which I have upgraded to the same unit as mentioned here in this thread Premium: 5N0 035 730 D.
I have only upgraded the Bluetooth unit as I understand that is what is needed (?)
I get the below fault codes in VCDS and I cannot set the car / Bluetooth unit into pairing mode (though the RNS 510 has seen the BT unit as PHONE menu now shows "SOS" and no phone connected).
I've searched for days for how to code Golf mk5 with this new BT unit and RNS510 but to no avail (I find a guide to soft coding but my VCDS only allows me to do "long coding").
Fault codes:
VCDS Version: Release 10.6.0
                Address 77: Telephone       Labels: 3C0-035-730.lbl
Control Module Part Number: 5N0 035 730 D    HW: 5N0 035 730 D
  Component and/or Version: Telefon       009 0511
           Software Coding: 020000000100000000010000
            Work Shop Code: WSC 00000 000 00000
              ASAM Dataset: EV_UHVPremi A01005 (VW35)
                      VCID: 2952FFFABFA33454
No ASAM data for: "EV_UHVPremi" (VW35)
5 Faults Found
9458451 - ROD - Unknown Error Code
             Freeze Frame
                    Fault Status: 00000001
                    Fault Priority: 4
                    Fault Frequency: 2
9458193 - ROD - Unknown Error Code
             Freeze Frame
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 150
                    Mileage: 38475 km
                    Date: 2000.00.00
                    Time: 20:41:22
13893632 - ROD - Unknown Error Code
             Freeze Frame
                    Fault Priority: 6
                    Fault Frequency: 5
                    Reset counter: 187
                    Mileage: 38445 km
                    Date: 2000.00.00
                    Time: 14:13:09
13633792 - ROD - Unknown Error Code
             Freeze Frame
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 185
0022 - ROD - Unknown Error Code
             Freeze Frame
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 187
                    Mileage: 38445 km
                    Date: 2000.00.00
                    Time: 19:37:37
Offline SteveP
« Reply #16 on: 11 April 2011, 21:48 »
That module won't work in a Mk5 as you need a White high line display to be able to pair the phones to it.
Offline Carrera-GTI
« Reply #17 on: 11 April 2011, 22:07 »
Thank you so much for such a quick reply!!!
Wow - what a poor purchase I made then  :cry: Are you 100% sure it wont work with mk5?
If I can't make it work, what module would I need to get premium Bluetooth with my RNS510 and iPhone 4?
Many thanks and I guess a "5N0 035 730 D" is on eBay soon...
Offline Buck
  • Das Auto
« Reply #18 on: 11 April 2011, 22:51 »
Hi
If this unit works with the iPhone 4 I'd bs interested at the right price ;)
PM if you wish. Adrian
Offline Carrera-GTI
« Reply #19 on: 11 April 2011, 23:05 »
Hi
Hi Adrian, I can't PM you as your email is hidden and I don't see how to PM you? Could you perhaps pm me?
PS: Yes this unit works with iPhone 4 ( a mate of mine bought the exact same unit for his mk6 GTI and works with his iPhone 4) apparently it is not compatible with my mk5...
Thanks
