Author Topic: Fault codes after RNS and Bluetooth upgrade on MK6 - HELP!!  (Read 24208 times)
Offline SteveP
Re: Fault codes after RNS and Bluetooth upgrade on MK6 - HELP!!
« Reply #30 on: 13 April 2011, 16:31 »
Thats a very very good price  :smiley:
Offline Buck
  • Das Auto
« Reply #31 on: 13 April 2011, 17:31 »
Cheers Steve - I though it was good too  :smiley:
I'm going to order it tonight if Darren's price isn't better but I think at that price it'll be a struggle.
Darren already coded the car for BT on Saturday when he sorted my stereo and a few other bits so should be plug'n play (crosses fingers)
Adrian
Offline Buck
  • Das Auto
« Reply #32 on: 13 April 2011, 21:08 »
Now ordered the BT unit as it was ending and couldn't let it go.
Just need a wiring kit now...
Offline Carrera-GTI
« Reply #33 on: 14 April 2011, 17:18 »
Hello - I need the following unit "1Z0 035 729 B" for my Golf mk5, can anyone please suggest where to buy it at the best price? I've seen it including wires (which I don't need) on eBay for app £300 but I was hoping for a better price (and don't need the cables).
Any help much appreciated!
Thanks!
Offline Buck
  • Das Auto
« Reply #34 on: 14 April 2011, 18:15 »
Christopher
Try eBay.de. There are lots on there. May be the one you need?
Try a seller called ukmegaseller he had lots of different models of the control unit
Adrian
Offline Carrera-GTI
« Reply #35 on: 30 April 2011, 18:21 »
Hello, I thought that I would report back.
I have now installed "1Z0 035 729 B" big thanks to Steve P for the advice!
I coded the unit to 0000422 and so the MFD menu appeared (the unit came with coding 0000000).
However, now my VW phone cradle stops charging my phone after the Bluetooth connection has been established - how weird is that? Where does the power for the cradle come from, does it run through the "1Z0 035 729 B" ?
Is this a common issue? Can I code something with VCDS so it starts charging again?
Car: 08/2008 Golf mk5 RNS 510 with factory fitted phone cradle and now upgraded BT unit to "1Z0 035 729 B".
Any advice is much appreciated! I have google a lot the last days and now found any mentioning of this issue.
PS: When pairing he "1Z0 035 729 B" is called Skoda something, is it really compatible with my Golf mkv?
Offline SteveP
« Reply #36 on: 30 April 2011, 18:32 »
^^^ Yes it compatible but as far as I am aware it's not designed for use with the cradle but could be wrong.
Offline Carrera-GTI
« Reply #37 on: 30 April 2011, 18:45 »
Hi SteveP and MANY thanks for your quick reply!
Is there a way I can verify that the "1Z0 035 729 B" is not compatible with a phone cradle? Is there a web link I can read about the compatibility or manufacturer description of the unit?
PS: I found it very odd that the phone charges and once the BT connection has been made it stops charging... It sounds like it should be able to charge but perhaps a VCDS coding issue? Is there any Adaption coding for the "1Z0 035 729 B"? Or is there coding to be made with the phone cradle?
Offline SteveP
« Reply #38 on: 30 April 2011, 18:48 »
Have a look a my-gti.com, this is may have some info on it about the 729b and cradles.
Offline Moshu007
« Reply #39 on: 22 August 2011, 13:03 »
On the telephone coding you need to set the baseplate to inactive. The control module not coded will clear after this is set.....
Hi Steve,
Hello there,
I have a problem coding my new 5N0 035 730 D bluetooth console.
To describe my problem:
I have a vw Passat 3C from 2008. I have the Premium UHV bluetooth phone connection, with MF steering wheel, keyboard for phone, buttons in the upper head console for service and info...
Under the passenger seat I had in the past the 5N0 035 730 bluetooth module, only rSAP compatible. Now I bought myself the new 5N0 035 730 D module which is HFP compatible too.
To make it work I need the new coding for the new 5N0 035 730 D otherwise is useless, I have tried all the combinations that I found on the internet and I am really desperate now.
Monday,22,August,2011,15:02:38:36838
VCDS Version: Release 10.6.2
                Address 77: Telephone       Labels: 3C0-035-730.lbl
Control Module Part Number: 5N0 035 730 D    HW: 5N0 035 730 D
  Component and/or Version: Telefon       009 0511
           Software Coding: 020000000000000000000000
            Work Shop Code: WSC 00028 028 00001
              ASAM Dataset: EV_UHVPremi A01005 (VW46)
                      VCID: 2952E120BFA33454
1 Fault Found:
9457427 - Negative output audio channel for speech/telephone
          B104F 13 [009] -- Open Circuit
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 47
                    Mileage: 155406 km
                    Date: 2011.08.22
                    Time: 14:04:35
