Author Topic: converting cable to hydro clutch  (Read 1220 times)
Offline Dan_GTi8v
« on: 21 January 2011, 07:08 »
I'm aware you can convert the 8v cable clutch to a hydraulic clutch by fitting the master and slave cylinders from a 16v, which I have purchased. As its getting close to the time I need to fit it, I've realised I actually have no idea how it works!
I know the master has a clip on the piston that attaches to the back of the clutch pedal, but how does the rest of the setup attached?
cheers :)
Re: converting cable to hydro clutch
« Reply #1 on: 21 January 2011, 10:10 »
theres a metal hydro pipe between the master and the slave, and a small section of flexi pipe from the side of the brake fluid reservoir to the clutch master cylinder. you may have the nipple on your old reservoir thats blanked off, you snip the blanky bit off the end then pop the pipe on. if its not there, then go scrappy hunting :)
Offline Khare
  • The bear that khares
« Reply #2 on: 21 January 2011, 13:39 »
Yup, and you do realise you need a hydro box right? The 020 is not.
Offline Dan_GTi8v
« Reply #3 on: 21 January 2011, 13:56 »
lol yeah I'm not that clueless though I may come across that way  :grin:
I'm converting to hydro when I put in the 1.8t and 02a box :)
Going from memory as they been in teh garage at mt dads for a while, I think I have the metal pipe attached to the master and I can get the flexi pipe from somewhere, how is it all actually held in place though does it bolt to something?
« Reply #4 on: 21 January 2011, 14:12 »
iirc its clipped into the plastic brake lines with like a double clip?
Offline Dan_GTi8v
« Reply #5 on: 21 January 2011, 16:13 »
I mean the cylinders themselves. sorry I'm not being very clear :P
« Reply #6 on: 24 January 2011, 08:54 »
bolts and nuts, its easy to figure out when you have the parts ;)
