Author Topic: Misting up help please : Split from another topic  (Read 5286 times)
Offline p3eps
Re: Misting up help please : Split from another topic
« Reply #10 on: 21 January 2011, 07:02 »
Turn the AC on when you drive in cold weather as it helps remove the moisture from the air.
I don't usually use the AC, but have been using it since my windows went down themselves one night when it was snowing!
I've also got a little tupperware pot full of silica crystals I leave on my dash when the car is parked up to help suck up the excess moisture and save my windscreen misting / icing up.
Golf R... 3 door, DSG, Leather, Reflex Silver, Black 19" Talladega Wheels, ACC, Parking Sensors, RNS510 with Dynaudio, Reverse Camera, Luxury Pack, Cruise Control & Fiscon Bluetooth.
Offline RickS
I wonder if this is what is causing the misting up i keep getting on the inside of the screen, now it's cold?!!?
Have you got your AC on the climatronic set to on [LED lit in button]? It can be turned off, maybe that's the problem.
No. Thanks anyway. Its only when I come back to my car after work in the evenings mainly. Just going to have to live with it
Unless you are getting a lot of water into the car somehow, the reason it's misting up is the AC not being on. The AC dries the air coming into the car. If you leave this on you will eventually eliminate the problem.
2012 R. Rising Blue 3 door DSG with 19" Talladega's, RNS510, Dynaudio, Cruise, DCC, Rear Cam, Colour MFD, Lux pack, Storage pack, Service plan.
Offline GolfTi
  • ..gotta feel for my automobile..
« Reply #12 on: 21 January 2011, 17:20 »
Good glass polish on the inside also helps.
Mk7 GTI. DBP, DCC, Winter pack. Mine since new, July 2013.
GTI no. 4. Golf no. 5.  VW no. 7.
Offline The Danno
« Reply #13 on: 21 January 2011, 18:34 »
My ac is always on. Perhaps it's cause I do really short 1 mile trips to the station which doesn't allow enough time fOr the ac to de humidify the air, or perhaps because my drivers side door is slightly out of alignment. A common R problem I believe.....?
Offline Jimble
« Reply #14 on: 21 January 2011, 20:48 »
My windows steam up if i've had the ac on on a wet day to clear them then switch it off, if that makes sense? I wonder if it's something like that?
Offline Jimble
« Reply #15 on: 21 January 2011, 20:50 »
Silica crystals sounds like a good idea, where do you get them from?
Offline am1w
« Reply #16 on: 21 January 2011, 20:56 »
I wonder if the heavy misting is because he is hot after exercise/rushing. Some people have naturally warm moist bodies (there was no better way of putting this). It used to happen to me after exercise due to being hot and sweaty.
Jimble: Just don't pounce on this one, please. :grin:
Offline Tone2have
  • Gutted - stolen April 10 but now black is back!
« Reply #17 on: 21 January 2011, 21:26 »
I was getting very misty however I didint tend to use the auto setting or aircon. I've certainly noticed a difference since I left the aircon on. I do find that having the climate controls on for a few mins before setting off usually de-mists the car perfectly, be patient young luke!
GTI MK6 black, man, 5 dr, 18" Monza shadow, Xenons, RCD510 Dyna Audio, Winter pack, ordered Sept 2009 - Delivered April 2010, stolen next day - gutted
Offline Alski
« Reply #18 on: 21 January 2011, 22:27 »
Got back off train tonight and thought I just needed to scrape ice on outside of screen. But turned out I was completely soaked up on the inside and it took a good 5 mins plus to start getting warm air to clear (was also much faster on passenger side than drivers !).
Was probably the worst I've had in any car and not helped that car was facing west into full sun as it went down which always seems to make it worse. Not sure if there's any cure as such, just need to try and keep as dry as poss and keep AC on to get drier air into car.
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #19 on: 21 January 2011, 22:30 »
That sounds like you have a wet carpet, boot floor or wet something somewere.
My Daihatsu winter runabout has a damaged drivers door(I bent it :embarassed:) that lets water in as it no longer seals and i have to do the same as you but i know my carpet gets slightly damp which causes it.
Mk6 GTI  &  Mk1 GTI
35 years of GTI ownership.
