Author Topic: How long does fuel last  (Read 2123 times)
Offline emery1990
« on: 20 January 2011, 20:59 »
Before it won't start your car anymore, pretty sure I've got like 25 litres in my tank, car hasnt been used since september.
Offline The Mighty Elvi
  • I'm better than you today.
Re: How long does fuel last
« Reply #1 on: 20 January 2011, 21:29 »
I left my car for 8 months with it just above the red line.  Plenty in it when I came to start.
It will evaporate over time though.
From The Internet:
According to Shell Australia’s Technical Advice Centre Manager, Warren Scott, you can generally store fuel in a sealed container for around six months before it starts to deteriorate. This assumes it’s kept relatively cool and away from direct sunlight.
“But if the container is not properly sealed or it’s repeatedly opened, [fuel] will start to evaporate and you lose some of the light components in the fuel,” Mr Warren says.
Those light components include highly important butane. As these components are lost, the fuel loses its volatility. Mr Warren says this makes the car difficult to start.
In warm conditions, fuel is especially prone to oxidisation which causes lacquer and gums to form. As a result, the fuel turns dark in colour, loses its clarity and smells like paint stripper.
Gary Whitfield, Senior Fuel Chemist at BP Australia, says that in the right conditions, fuel can last up to 12 months. But once the container is opened, the fuel will start to degrade.
“Once the seal is broken, a vapour space is formed in the container and the fuel will start to deteriorate more rapidly,” he says.
Okay, so what about fuel that’s left in your car’s tank for a long period of time?
Mr Whitfield claims fuel in a car’s tank can last for up to four weeks before it becomes considerably denser. When this happens, the engine is effectively over-fuelled (without any change in injector pulse-width) and there’s an increased chance of carbon deposition onto spark plugs and inside the combustion chamber. This can cause driveability problems such as stutters and misses.
“Regular unleaded fuel will lose a small amount of octane over time but in our low-sulphur and high detergent Ultimate fuel it might increase very slightly. It might increase 1 RON in four weeks – but it’s not something I’d bother chasing,” he says.
“Keep in mind that typical variation in BP Ultimate is 98 – 100 RON while normal unleaded ranges between 91 – 93 RON.”
Mr Warren says that in most cases, it’s only when fuel is left in the tank for several months there’s the risk of engine damage. This is much more likely to occur in cars running dual LPG/petrol systems.
“By this time the fuel will have gone dark and gummy and can clag the fuel pump, filter and injectors,” Mr Warren says. It can also leave a lacquer deposit on the inside of the fuel tank which is difficult to remove.
In addition, it’s important to be aware that fuel brews – specifically fuel volatility - varies on a month to month basis. Standards vary from state to state but, generally, volatility is reduced during summer months to reduce evaporative emissions. Mr Whitfield says this typically makes the engine slightly harder to start but there is no change in octane.
Lachlan Riddel, proprietor of Gold Coast based tuning company ChipTorque, frequently dyno tests cars which have not previously been driven for several weeks.
“On the fuel mix we have in Queensland, I think fuel in a car’s tank is starting to go off in around three weeks,” Mr Riddel says. “We can tune a car, put it away for three of four weeks, come back to it and it will be either closer to detonation or less likely to make the same power.
“I think local fuel is brewed to reduce evaporative emissions in warm weather and, maybe because of that, fuel really goes crappy in eight to ten weeks. By that stage, the fuel is extremely prone to detonation.”
Interestingly, Mr Riddel hasn’t noticed the engine becoming harder to start but the effect on octane is pronounced.
Similarly, the General Manager of Melbourne’s Advanced Vehicle Operations, Steve Coates, believes fuel tends to go off in a car’s fuel tank quite quickly once it’s a couple of weeks old.
“After a couple of weeks not driving a car, I find that it will be closer to detonation than it was at the time of tuning on the chassis dyno,” he says.
“And the brand of fuel seems to make a difference as well – I find that Mobil and BP products are probably the best after being stored but Shell Optimax is really good when it’s new."
Clearly, there are some important factors to keep in mind when storing fuel in a container for several months or when parking your car for a few weeks.
Our recommendation is not to run the engine at high load with fuel that’s been in the tank for any more than three of four weeks and it’s a good idea to add at least 25 percent fresh fuel to the tank every few weeks. This will help ensure there are no fuel-related driveability problems or detonation and will reduce the chance of lacquer building up inside the tank.
Comments
END.
Offline emery1990
« Reply #2 on: 20 January 2011, 21:42 »
Cheers  :smiley: Ill put in a jerry can or two before I starts it up, fingers crossed!
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #3 on: 21 January 2011, 16:22 »
I laid up my Audi S2 for 6 years and the old fuel started her up just fine!!
For More Info Click To See;
Offline Baylez8v
« Reply #4 on: 21 January 2011, 16:32 »
i could fill my mk2 with shredded newspaper, leave it for a a decade, come to it in the depth of winter and it would still stary first time lol
but seriously, i have had it sat for a year with a dribble in the tank and she starts first turn of the key
Offline leigh_harty
  • Audi AGU
« Reply #5 on: 21 January 2011, 17:03 »
Golf2's run on love, not fuel  :nerd:
Dont lose your dinosaur!
gixer1400
« Reply #6 on: 22 January 2011, 00:18 »
and warmth from the owner, not the heater  :laugh: :laugh:
Offline MiniDan
« Reply #7 on: 22 January 2011, 00:25 »
Was given a Fiat Strada a while ago that had been sitting in a garden for 8 years.
Stuck a battery on and it fired straight up :grin:
Need your car or parts transporting? Engines, wheels, panels, etc. PM me for a quote.
Fully insured and cheap rates. Discount for forum members.
