Author Topic: Dash Heater Control Lighting has Busted...  (Read 2543 times)
Offline les.tansey
  • VW Golf R32 MK5 & Mercedes-Benz E320 CDI Estate
« on: 20 January 2011, 18:45 »
Dash Heater Control Lights are Out, I've changed all of the fuses and they still don't work... is there anything else I can do or does the whole unit need replacing? - Its just that i've heared that its a fully sealed unit...  :undecided:
Any advice on what to do next?
Cheers, Les. :cool:
(As above) Golf MK3 & genuine BBS RX 16"wheels, now for sale separately - Just ask for details - Thanks, Les
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: Dash Heater Control Lighting has Busted...
« Reply #1 on: 20 January 2011, 18:53 »
It'll more than likely just be the bulb that has gone mate. Theres a single tiny capless bulb fitted behind the controls that simply pulls out. These often go on mk3's seeing as they're bloody old now. Just pop the facia off from around the three heater dials and remove the ashtray then you'll see 4 screws holding it the centre section of the dash in. Withdraw the controls and on the back of them you'll see a white plastic shroud, pop that off and you'll see the bulb and green filter surround. VW sell them for less than a quid.
Offline les.tansey
« Reply #2 on: 20 January 2011, 19:44 »
Cheers mate i'll try and give that a go over the weekend, sounds simpler than I thought.
Cheers :wink:
« Reply #3 on: 20 January 2011, 20:08 »
No worries, seriously it's a doddle to sort out.
Offline clivusdel
  • Mk3 Golf GTi 8v
« Reply #4 on: 20 January 2011, 20:15 »
or, if you can fit an led, as it will out last the bulb, then you dont have to change it again
Offline luckycharms
« Reply #5 on: 20 January 2011, 20:29 »
I had a nightmare getting the panel off enspite of it being a simple job!
Then forgot to put the little green shade thingy back on so i've now got white heater controls  :grin: :grin:
