Author Topic: Stereo turns back on  (Read 1774 times)
Offline golfmk4owner
« on: 20 January 2011, 17:33 »
Hi guys, very odd but as normal when i turn my car off and take the key out the stereo turns off but then sometimes, but not all the time, turns itself back on (with the key out mind) after a second or two. It then takes anything up to ten seconds to turn back off automatically finally. Very strange when i gotta sort of get out the car, pause a few seconds for it to turn back off, then close my door.
Any idea why? Its so odd
Cars a GT TDI 140, radio has recently been upgraded to a RNS 510 bit IIRC it did it with the factory one too.
2005 GT TDI 140 - Standard as F@k
Offline AlanD
  • MK5 2.0T 16v
Re: Stereo turns back on
« Reply #1 on: 21 January 2011, 17:32 »
You need to be sure it was doing it with the old headunit. I don't believe in coincidences. If it's only been doing it since the upgrade then there must some wires crossed somewhere.
« Reply #2 on: 23 January 2011, 11:26 »
Yes it did it with the last one, because i was kind of hoping that the upgrade would also fix the problem at the same time, but clearly not. Any idea what the problem is?
Offline pluslyn
« Reply #3 on: 25 January 2011, 17:53 »
Is your car a MK4 or MK5? for a start.
Who upgraded your Radio? reason I ask is have you had to upgrade your Can Gateway,
(I have 55 Mk5 & when I upgraded from a RCD310 t0 a RCD510 I had to upgrade the Can Gateway & copy the settings)
(the RCD510 did not match my old Gateway)  This is a known issue.
« Reply #4 on: 25 January 2011, 18:45 »
Well the cars a mk5, hence its in the mk5 section lol, but i didnt state that clearly.
And i changed it myself, there were no issues when changing, the loom fitted fine and the stereo worked straight away.
Its an intermitant problem - the past two days it hasnt done it, but few days before that it was doing it, and itll do it again im sure.
Also like i said, the previous factory stereo did the same thing, its as if its a fault on the key switch if there is such a thing?
