Author Topic: exhaust fitment  (Read 1167 times)
Offline stainesy
exhaust fitment
« on: 19 January 2011, 18:59 »
ok im looking for a good exhaust for my car. now buying brand new but have found a few 2nd hand stainless ones but a few are for the 16v.
mine is the 8v will the 16v ones fit? or do i have to buy 8v exhaust?
Offline dom
  • Back in a Mk4
Re: exhaust fitment
« Reply #1 on: 19 January 2011, 19:09 »
The bore of the pipe exiting the cat is 50mm on both 8v and 16v so as long as you get it from the cat back it will fit fine.
It is also worth noting that the bore of the pipe increase to 55mm on the 16v between the cat and middle silencer so the 16v backbox alone will not fit an 8v :smiley:
Offline stainesy
Re: exhaust fitment
« Reply #2 on: 19 January 2011, 19:16 »
ok great so as long as i get the system from cat back it will fit fine yeah.
nice1 mate. thats a result
Offline boneybradley
  • Back in a Mk3...
Re: exhaust fitment
« Reply #3 on: 19 January 2011, 19:52 »
just buy the 16v connector pipe (between cat and downpipe) and you can then fit the 16v/vr system
Offline dom
  • Back in a Mk4
Re: exhaust fitment
« Reply #4 on: 19 January 2011, 20:46 »
He doesn't even need to do that, i'm assuming that's his P reg gti in his sig? Same year as mine and a 16v system fitted on mine from cat back with no problems at all. The bore of the exit pipe from the cat is the same on the later 8v as it is on the 16v/VR6, so unless he's fitting a decat he won't need to change anything.
Re: exhaust fitment
« Reply #5 on: 20 January 2011, 10:34 »
yeah the 8v/16v cat is the same bore, its from the rear silencer back the 8v goes down to 50mm. i think though theres a difference in cat length depending on age of car, so this is something to bear in mind
