Author Topic: Slow response from accelerator  (Read 2147 times)
Offline vw-john
« on: 18 January 2011, 19:53 »
when at low revs my car seems to struggle to accelerate. feels like the fuel isnt getting into the engine when the accelerator is pressed, really laggy
Offline Mike87Turbo
Re: Slow response from accelerator
« Reply #1 on: 18 January 2011, 20:07 »
Check for pressure at the fuel rail and check spark/spark plugs/oil first off. If everything seems to be ok then id get a code read done to see if theres any faults stored??
Offline dom
  • Back in a Mk4
« Reply #2 on: 18 January 2011, 22:05 »
It's a Mk3 - deal with it :lipsrsealed:
« Reply #3 on: 18 January 2011, 23:31 »
Lol  :laugh:
Offline gasketface
« Reply #4 on: 18 January 2011, 23:39 »
do'nt drive with doc martins on,they hit the brake pedal at the same time ?.
« Reply #5 on: 19 January 2011, 10:34 »
what engine is it to start with
Offline vw-john
« Reply #6 on: 23 January 2011, 12:31 »
Its an ABS engine. got a code read, and it said permanent fault with distributor something. so i looked at the cap again, the connectors were fried. so replaced that. still has problems though. the rotor arm looks brand new. the spark plugs are all fine. and i have cleaned the throttle body.
where is the fuel rail located and how do I check the pressure?
cheers
Offline vw-john
« Reply #7 on: 26 January 2011, 14:37 »
bump :smiley:
Offline davies1644
« Reply #8 on: 26 January 2011, 14:43 »
its not gonna be the fuel rail pressure if it is only doing it low done it cant be this as they only run 60psi pressure which itll always have
Offline javalin
« Reply #9 on: 26 January 2011, 14:47 »
these sorts of problems are usually ignition based - so coil, wires, sparks, dizzy cap & arm.  If that fails I'd be checking CAM sensor condition, crank/cam and ignition timing and then possibly O2 sensor
Have a read : http://javalins.wordpress.com/vw-golf-mk3/troubleshooting-common-fixes/
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
