Author Topic: slight play in steering rack  (Read 1114 times)
Offline delirical
  • Like a g60
« on: 18 January 2011, 17:47 »
Hi guys,
If you grab the wheel and push up and down there is a small amount of movement, when turning a corner and foot resting on the clutch you can feel movement/friction relating to turning the wheel.. any ideas? is there something that just need tighterning? do i need to take all the dash out to get access? :sad:
Alex
Offline walchy01
Re: slight play in steering rack
« Reply #1 on: 18 January 2011, 21:43 »
No mate dont drop the dash out, take plastic cover off below steering wheel and plastic trim below that think 5 screws, have a look up for what should be 2 silver nuts, they need tightening up 1 of em is a real twit to get too :grin:
Offline delirical
  • Like a g60
« Reply #2 on: 19 January 2011, 08:13 »
Lovely Jubly!
Thanks for that mate, ill have a look on Saturday  :smiley:
« Reply #3 on: 19 January 2011, 10:42 »
there is 1 bolt holding the lock housing to the outer colum tube which often loosens itself, you dont even need to remove the lower cowling to get to it there is a hanfdy access hole in the cowling. though its only 2 screws to remove it, makes it easier to see what you are doing :)
Offline delirical
  • Like a g60
« Reply #4 on: 19 January 2011, 17:48 »
Even better!
Thanks guys.
