Author Topic: MK 3 illumination  (Read 4353 times)
Offline Brin
MK 3 illumination
« on: 27 August 2003, 23:36 »
hi guys
Does anybodys 3 round knobs that control heaters ETC in MK3 Golf look dull at night or has mine got blown bulbs ? and if they are how do you get at them ?
Cheers Neil
golfvr6
Re:MK 3 illumination
« Reply #1 on: 27 August 2003, 23:38 »
To check them simply pull the dials off, if you need to change the bulbs use a pair of long straight tweezers.
Offline adyh
« Reply #2 on: 28 August 2003, 10:41 »
i just want to know why the rear heated window switch never seems to light on a VW
golfvr6
« Reply #3 on: 28 August 2003, 13:58 »
A fuse maybe? or the switch is probably broken.
Offline adyh
« Reply #4 on: 29 August 2003, 09:38 »
no the light comes on , i mean backlight  / illuminated
golfvr6
« Reply #5 on: 29 August 2003, 13:29 »
Got to be bulbs then i suppose.
Offline Young Brin
« Reply #6 on: 30 August 2003, 18:43 »
Mate,
Mine are brightish at night although the nearside one of the three is slightly duller than the others which gives the appearance of a blown lamp. ::)
Offline modulater
« Reply #7 on: 05 September 2003, 02:49 »
The older the bulb the dimmer it will light up, Thats why you always get 2 bulbs in a packet when you buy brake light bulbs, you should replace both so that they light up with the same intensity.
Also I think only the main safety switches have a backlight, I.e hazards and fogs.
You got me wondering about my heated rear window switch, does it light up?
golfvr6
« Reply #8 on: 07 September 2003, 17:51 »
There you go mate , change the bulbs  ;)
Offline adyh
« Reply #9 on: 09 September 2003, 11:50 »
Whats the answer Modulator .... mine definatly does not . And i had an old polo that was identical ..... maybe i just had two knakcered switches.
