Author Topic: Q? Service indicator, how to change from longlife to time and distance?  (Read 3932 times)
Offline Snoopy
  • Moderator
  • Geoff.
Mk6 GTI  &  Mk1 GTI
35 years of GTI ownership.
Offline RedHP
Not through MFD....?
Mk6 GiT since birth in 2010
YNWA
Offline RedHP
If not, then would be down to the dealer mechanics who can set/reset this...?
YNWA
Offline Rhyso
VAGCOM - think its under Module 17 - instruments
Might be some other modules you need to tinker with too though  :undecided:
Offline The Doc
  • E63s Estate - Vito Sport
You can do it using VCDS - just put Doc jnr to bed and Mrs Doc is at work making us safe as we sleep so I cant go and do it now  :sad:
I'll do a "how to" on it in the morning if you can wait  :wink:
Offline Snoopy
  • Moderator
  • Geoff.
When have i ever been in a rush to do anything  :grin:
Mk6 GTI  &  Mk1 GTI
Offline mike.
Just did this yesterday myself, as I had asked the dealer but they left it on Variable  :rolleyes:
The MK6 uses the UDS protocol so you can't use the service applications in VCDS
You can do it the following way.
Go Into 17- INSTRUMENTS, and then ADAPTATION
Go to the following channel and change it from ESI to SID
I also changed the mileage to 16100km which equates to approx 10000 miles, I think it was set to 9800 miles
And the time to 365 days as it was set to 372
Resetting the service on the MFD now sets it to 10000 miles or 365 days.  :smiley:
Mk6 GTI 3dr | DSG | Tornado Red | 18" Monza 2 | LED Xenons | RNS510 | Bluetooth | Smoked LED tails | Cruise | Reversing Camera | TPMS | - now sold :(
Offline Snoopy
  • Moderator
  • Geoff.
Thanks, i will try this at the weekend :smiley:
Mk6 GTI  &  Mk1 GTI
