Author Topic: New sills needed - Where to buy?  (Read 9258 times)
Offline robo22sri
Re: New sills needed - Where to buy?
« Reply #30 on: 23 July 2012, 17:08 »
Threas bump!
None of the links work and i need new inner and outer sills :(
VW BUSH
« Reply #31 on: 23 July 2012, 18:07 »
Threas bump!
You need a new Mk3 then, unless you are handy with a welder and paint will cost ££££
Offline robo22sri
« Reply #32 on: 23 July 2012, 18:17 »
my mate is a welder/ fabricator ;) but thought it would be easier to buy the sills to weld in
VW BUSH
« Reply #33 on: 23 July 2012, 18:24 »
It is a much cleaner job like that but quite a lot of work, look at TShirt2k or GTI Jamo's build threads.
Hope your friend works for Beer money :wink:
Offline Len
« Reply #34 on: 23 July 2012, 23:57 »
Had mine done for £150, I supplied the sills and did the painting.
www.sas.org.uk
www.the-ace.org.uk
Offline robo22sri
« Reply #35 on: 24 July 2012, 10:30 »
where did you get the sills from????
Offline Len
« Reply #36 on: 24 July 2012, 12:37 »
That supplier I posted in the cab wings thread.
www.sas.org.uk
www.the-ace.org.uk
Offline Len
www.sas.org.uk
www.the-ace.org.uk
Offline Shady Pioneer
  • graphic designer.
« Reply #38 on: 24 July 2012, 13:39 »
Is that the outer sill Len?
Offline Len
« Reply #39 on: 24 July 2012, 15:12 »
YES!
I would be dubious of doing inner sills, patch with chassis grade sheet, depending on how bad they are.
www.sas.org.uk
www.the-ace.org.uk
