Author Topic: Windscreen wash leak rear  (Read 1319 times)
Offline chana22
  • Vw Golf GTi 8V
« on: 16 January 2011, 22:50 »
hi all
just wondering if anyone knew what i have to do or where i should be looking to get my rear wash n wipe water working again
over the winter it stooped spraying water to the rear but i have noticed the motor is still pushing water out but it seems to be leaking out of the rear driver side wheel arch (outside).
any ideas?
also, the pressure has dropped from my front spray jets as-well
thanks.
Offline Simeon
Re: Windscreen wash leak rear
« Reply #1 on: 17 January 2011, 11:23 »
Pipe runs down o/s of car I believe to the boot then up the c-pillar and into the tailgate. Pull your boot carpets up and have a look.
Offline tony_ack
« Reply #2 on: 17 January 2011, 12:50 »
^^^ Yep it's on the offside. Take out the turret carpet/foam from inside the boot, and you should see the pipe running inside the chassis up the C-pillar. Follow it down and you should come to a connector for the pipe. My first guess would be that the pipe has come away from the connector.
1992 VW Golf MK2 GTI
1995 VW Corrado VR6
