Author Topic: trackday  (Read 1161 times)
Offline adam 180t
  • mk4 auq
trackday
« on: 16 January 2011, 20:34 »
hey guys got a trackday for crimbo was wondering what to do to my car b4 i go coilies any suggestions
Offline Peej1981
  • Its Whats Under The Hood That Counts........
Re: trackday
« Reply #1 on: 16 January 2011, 20:39 »
Seller yours and buy a mk1 or mk2  :laugh: :laugh: :laugh:
www.bombercountydubs.co.uk
Offline adam 180t
  • mk4 auq
Re: trackday
« Reply #2 on: 16 January 2011, 20:44 »
no cant afford that and really cant be arsed to selll another car its a f***** hassle jus wanna take this one round
Offline Peej1981
Re: trackday
« Reply #3 on: 16 January 2011, 20:56 »
I was only joking mate, there not actually that bad around a track. Have you already got collies for it? I would just make sure that the car is running absolute spot on before you take it on, yeah the suspension will defo help but when you put it on make sure you run the collies in first, i would put them on at the standard height and run them for a bit until they are bedded in then slower it, when yoou lower if make sure you get the thracking and camber soorted too as this will change. As long as the suspension is set up spot on too then yoou already have a good engine and should have a lot of fun. Check that you breaks are also in good condition, engine is running good, boosts ok, airfilter clean and oil is clean and at the rite level.
Are you looking to just have a bit of fun or planning on doing it on a more reg basis??? If more reg then you need to get yourself onto the track section of the forum which would help you a lot more to set your car up  :grin: :grin:
Offline Diamond Hell
  • Opinions я Us
Re: trackday
« Reply #4 on: 16 January 2011, 21:20 »
Finding and replacing and worn bushes will be a much better way to spend time and money, as well as a full alignment session, instead of p*ssing about nailing cheap, sh*tty coilovers into it.
Make sure you have plenty of meat on your brake pads.
Make sure you have plenty of meat on your tyres and they're not ling long specials.
Make sure you don't have any fluid leaks.
Take everything loose out of your car (including your girlfriend).
Offline Chris-White
  • Manufactured in Germany. Ruined in Britain.
Re: trackday
« Reply #5 on: 16 January 2011, 21:40 »
Pads
brake fluid replaced
oil change
T1-R's & 4 wheel laser alignment (not at kwikfit)
Fix any leaks
Enjoy. Prepare to be addicted.
Offline adam 180t
  • mk4 auq
Re: trackday
« Reply #6 on: 16 January 2011, 21:57 »
Mightbe a one off but not sure yet bushes are all ok gonna give it a service myself b4 i go so everything will have a good check over
  • Opinions я Us
Re: trackday
« Reply #7 on: 16 January 2011, 22:01 »
Good call on the brake fluid from Chris.
Check the bushes and suspension for play all round - track driving will flush any weaknesses out.
Offline jonnypolish
  • t2871r needed :)
Re: trackday
« Reply #8 on: 16 January 2011, 22:27 »
LOL that actually cracked me up :afro:
 MK2 VR y0!
