Author Topic: Bark in my heater fan :(  (Read 1585 times)
Offline bmouthboyo
« on: 15 January 2011, 18:56 »
Hi,
I was doing some work today and had teh plastic covering off under the wipers so I could get access to the clutch cable hole.
I checked the polen filter and as I pulled it up some crap must have fallen in as when I now use my blowers I can hear it getting smashed about by the fan under the dash on the passenger side. Very noisy.
Is there an easy way to get access to clean it out? I tried full pelt fan to blow it out but not happening.
Thanks
Re: Bark in my heater fan :(
« Reply #1 on: 15 January 2011, 19:33 »
The only way really is to remove the pollen filter and clean it out.
Offline bmouthboyo
« Reply #2 on: 15 January 2011, 19:50 »
But wont it be further down now and not accessible from the pollen filter area?
Is the fan easily removed? I did the fan in a T25 camper and it was a nightmare (dash out job) :(
« Reply #3 on: 15 January 2011, 20:00 »
Doubt it has gone further down, I believe if you drop the pass. side dish undertray you will see the motor, undo the bolts and it should drop down.
Offline bmouthboyo
« Reply #4 on: 15 January 2011, 20:04 »
Ah ok thanks.
Due to the noise it must have gone into the fan though no? If so how will going in from the pollen filter get to it?
Sorry I didn't really look into the vent when I checked it.
Thanks
« Reply #5 on: 15 January 2011, 20:07 »
Ah ok thanks.
Thanks
Just drop the motor and clean it out, chek the pollen filter area 1st however in case it is stuck.
