Author Topic: Smokin hot!!!  (Read 1460 times)
Offline Seanl
Smokin hot!!!
« on: 15 January 2011, 14:23 »
Just sprayed the inside of headlights and they look brilliant! However, I left one of em in the oven too long and melted the plastic casing, and all the retaining clips. Ooops! Well after a shot with the heat gun I managed to bend them back enough to fit. Thought I better test them for this reason, and low and behold, it keeps popping fuses :(        Had enough now though, gotta finish off spraying the grille so I will look at it later cos I can't be bothered!
Offline The Mighty Elvi
  • I'm better than you today.
Re: Smokin hot!!!
« Reply #1 on: 15 January 2011, 14:55 »
Uh!
You sprayed inside.  The reflective bit?  :rolleyes:
Offline Mitching
Re: Smokin hot!!!
« Reply #2 on: 15 January 2011, 15:06 »
Uh!
I heard that bit's quite handy  :lipsrsealed:
Offline VR6_Wherry
Re: Smokin hot!!!
« Reply #3 on: 15 January 2011, 15:13 »
I assume he has a mk3, in which case you can spray parts of the inside that's not reflective. It's called the Joey mod, most of us have done it  :smiley:
http://forums.vwvortex.com/showthread.php?1567138
Offline Seanl
Re: Smokin hot!!!
« Reply #4 on: 15 January 2011, 15:24 »
Yeah it's a mk3 and yeah it's a Joey mod. It's not the reflective cones but the outside lips of them. Bit pikey but I think it looks good!
Re: Smokin hot!!!
« Reply #5 on: 15 January 2011, 15:26 »
Should be posted in the MK3 section then.  :rolleyes:
Offline cняis
Re: Smokin hot!!!
« Reply #6 on: 15 January 2011, 17:06 »
i love the way you mk3 bwoys call it the joey mod. who the f' is joey?  :laugh:
Offline Seanl
Re: Smokin hot!!!
« Reply #7 on: 15 January 2011, 17:41 »
No idea who Joey is, possibly the first person to post here how to do it I suppose. Thought it was better of on here though as the mk3 section is more question based, where as this is general vw chit chat and I thought my idiocy was best shared with all!
Offline Jimp
Re: Smokin hot!!!
« Reply #8 on: 15 January 2011, 19:24 »
Some guy who did it first and posted on vwvortex about it. I think he was American. Not sure if he first did it on a mk3 or some other car.
Not low enough mk5
Not on the road enough mk3
