Author Topic: Electric window motor advice please  (Read 2133 times)
Offline walchy01
« on: 14 January 2011, 19:22 »
Hi there
I am after a replacement electric window motor, my question is where is the best place to buy one and how much??? And can u still buy these Original replacement from Vw???
Thank you
Offline The Mighty Elvi
  • I'm better than you today.
Offline emery1990
Re: Electric window motor advice please
« Reply #2 on: 14 January 2011, 20:36 »
http://www.veedubmachine.co.uk/index.php?main_page=advanced_search_result&search_in_description=1&keyword=window+motor
Where I got mine mate, been fitted for 8 months now. Downside to fitting was that you had swap the polarity around as when wired up to what I thought ground and live it spun the motor the wrong way, ie up was down etc.
Offline dadrathers
« Reply #3 on: 14 January 2011, 20:50 »
Try Pete Simpson at Dubbers Sports VWs - I got motor and mech from him made by same company that made them for VW - you can tell by the weight of the motor that they are not cheap replacement parts. 07796 304790 at Nabbs Lane in HD7 5AU
Offline walchy01
« Reply #4 on: 15 January 2011, 13:25 »
Thanks do that, is it advisable to replace both motor and mechanism??
Thanks
Offline dadrathers
« Reply #5 on: 15 January 2011, 20:18 »
I had to replace the mech as I was replacing the hand windy things. But I would say advisable anyway - you will likely find that there is play in the clamp that moves up the guide - there was loads of play on mine on the driver's side but OK on passenger's side and whilst they were manual the same will be true of electric.
Offline walchy01
« Reply #6 on: 15 January 2011, 21:30 »
Ok thanks the job lot it is then....
Offline tony_ack
« Reply #7 on: 16 January 2011, 13:18 »
Mech and motor usually come as one.
Which side is it you're after? I got a Dubber's driver's side one about a year and a half ago... 6 months later I had to break the car due to a shunt. I still have the mech and motor if you're interested?
1992 VW Golf MK2 GTI
1995 VW Corrado VR6
Offline tony_ack
« Reply #8 on: 16 January 2011, 13:21 »
By the way - I wouldn't recommend the ones from veedubmachine - I got one from there before I got the one from dubbers VW, and it failed after 1 week!
1995 VW Corrado VR6
Offline walchy01
« Reply #9 on: 16 January 2011, 19:21 »
Tony
PM'd you mate
Thanks
