Author Topic: cooling system  (Read 1713 times)
Offline captin_urbis
cooling system
« on: 14 January 2011, 17:15 »
just changed my head gasket and now i have come across a problem. the car wont bleed properly. it heats up very quickly and then bubbles all the water out of the header tank.
im guessing it is due to an air lock somewhere. but i cant seem to find it, does anyone have any other ideas??
Offline SimonG
Re: cooling system
« Reply #1 on: 15 January 2011, 14:17 »
If you think you've got an air lock, pump the top and bottom radiator hoses to 'pump' coolant around the engine and into the heater matrix.  If you have, you should notice the coolant level in the header tank drop and bubbles appear.
  Mk3 Anniversary GTI 16V, Mk2 GTI
Offline X4MGS
  • VAG Parts SNOB!!!
For More Info Click To See;
Offline dadrathers
Re: cooling system
« Reply #3 on: 15 January 2011, 20:14 »
Make sure there is coolant coming out of the overflow pipe from the top of the rad to the header tank with the cap off when you rev the engine. I had a similar problem and found I was not getting the overflow becauu the outflow pipe was blocked just inside the radiator. Cleared it and got my stream of coolant into the header tank and all was well. Before I did this it used to pressurise the system something rotten.
Worth a check.
Offline mk2bal
Re: cooling system
« Reply #4 on: 15 January 2011, 22:02 »
Also why did the headgasket go?did it overheat? Could be knackered water pump?
