Author Topic: Holding back feeling when accelerating....advice please  (Read 3431 times)
Offline walchy01
hi there
I took the car out today,a mk2 16V gti, when i was accelerating i could feel the car struggling to power away from memory this happened in all gears,this aint normal on my car :sick: :sick:.... any ideas guys?? :wink: :wink:
Thank you
Offline BiGUKG
  • Simples!
Re: Holding back feeling when accelerating....advice please
« Reply #1 on: 13 January 2011, 18:20 »
Be interesting to see what this is put down to - don't know much about it tbh but air flow can cause it.
No odd noises?
http://www.vw-southeast.co.uk
"The community for enthusiasts and owners in the South East"
Offline Neo Badness
  • Feet are for pedals
« Reply #2 on: 13 January 2011, 18:26 »
16v? Holding back? Check the timing, had the cambelt done on mine a while back and it was flat, turned out it was out by a couple of teeth.
Offline danny_p
« Reply #3 on: 13 January 2011, 19:36 »
fueling
check the warm up reg is actualy doing what it should do, includeing wot enrichment
« Last Edit: 13 January 2011, 23:19 by danny_p »
all the VW's have gone bar 1.
VeeDubGTI16v
« Reply #4 on: 13 January 2011, 19:58 »
more likely to be spark if its happened suddenly, check the leads are ok for starters
Offline Mitching
« Reply #5 on: 13 January 2011, 23:43 »
Mine felt like that.
Then it seized.
Offline delirical
  • Like a g60
« Reply #6 on: 14 January 2011, 08:32 »
Yea mine was holding back because the timing was out and it was so badly tuned.
Offline twistedblack69
  • Proud mk2 user and abuser
« Reply #7 on: 14 January 2011, 10:29 »
HY
I was going to say this as it has jus happened on my 8v, turns out the cap rotor arm its broken so I'm changing that, plugs and leads.
Offline walchy01
« Reply #8 on: 16 January 2011, 19:19 »
Hi there
Cambelt done 1K ago,leads,plugs,all filters done 1k ago, rotor arm all in place and newish....
Was out in it today after having some replacement struts done, car feels so smooth now :smug: :smug:
It fine until i started a steep hill climb about 1:8 then it really really felt like it was not going to pull me up the road.really struggling for power....then it just found its power and pulled me all the way up and home... can the ISV have anything to do this....or is that just for something else??? :rolleyes:
Any further advice much welcome :wink:
Thank you
Offline Neo Badness
« Reply #9 on: 16 January 2011, 21:36 »
is it only when you go up hill? Could be fuel pick up?
