Hi Javalin,
As far as I can work out, it is scanning the ABS because when selecting the ABS to scan, it begins clicking away behind the dash. That said, no information is pulled through into the Controller info window of VCDS, like
"Vag number", "component", "soft coding" etc
I don't know if information is meant to be transferred over but it certainly is when the engine or airbag is scanned.
Because there is a fault that VCDS isn't picking up, I am led to believe the abs module under the bonnet is knackered. Would you agree?
