Author Topic: Re: Golf Sunroof Problem  (Read 2891 times)
Offline dashey
« on: 12 January 2011, 00:13 »
mate, im having the same problem now i have changed the motor n switch checked to see if power is going to the motor and in theroy it should work have you managed to sort it?
Offline andc1
« Reply #1 on: 12 January 2011, 07:38 »
if you cant here the motor i would say motor has gone
Offline dashey
« Reply #2 on: 12 January 2011, 14:54 »
No because i swapped motors with my brother and his still worked and mine didn't so something haa gone wrong somewhere
Offline mcgee9t2
« Reply #3 on: 12 January 2011, 16:22 »
Checked to see if there's any current getting to the motor?
Offline dashey
« Reply #4 on: 12 January 2011, 16:34 »
Yeah checked that checked switch checked for break in wires im lostt might just turn into a manual one if i cant solve it
Offline Rhyso
« Reply #5 on: 12 January 2011, 16:37 »
Any problems with any of your other electrics??  Or is it just the sunroof that isn't working
Offline dashey
« Reply #6 on: 12 January 2011, 20:48 »
Nah all my other electrics are fine has no 1 else had this problem?
Offline dashey
« Reply #7 on: 12 January 2011, 20:53 »
Sorry its a mk3 i know this says mk4 only just realised now sorry for inconvience just proper frustrating
« Reply #8 on: 12 January 2011, 23:47 »
If the motor is working then it has to be a wiring / power feed problem.
« Reply #9 on: 13 January 2011, 09:28 »
does the switch light up?
