Author Topic: number plate surrounds  (Read 1549 times)
Offline -danisdubbin-
  • The golf is dead :(
« on: 12 January 2011, 13:16 »
hey guys, just did a quick search on the forum for the best way to fix a pressed plate into the surround
the decision seems to be adhesive tape!
what have other people used, i was thinking of maybe using araldite .... or some other high strength adhesive glue?
reccomendations?
cheers guys, cant wait to get these bad boys on
dan
Staceman ' i struggle not to w**k over that jetta sometimes '
Golf Mk3 Gti 8v 96 Storm Grey - Dead
Re: number plate surrounds
« Reply #1 on: 12 January 2011, 13:37 »
Trim tape is your best bet.
« Reply #2 on: 12 January 2011, 13:46 »
trim tape, cool , where can i get some of that stuff from wayne mate?
never heard of it before
Offline boneybradley
  • Back in a Mk3...
« Reply #3 on: 12 January 2011, 13:50 »
trim tape and plate holders dosent always work! does you plate holder clip the plate in? if yes then use a couple of self tappers for the front holder and 2 bolts for the rear then clip the plates in, if not ensure you clean (pre paint panel wipes are best) and warm the area where the tape is going to go
« Reply #4 on: 12 January 2011, 14:01 »
nah they dont clip in mate, they are the surrounds from the golfgti.co.uk shop ......
ok cool, ill give that a go, hope it works ok, ta for the advice
Offline VR6_Wherry
« Reply #5 on: 12 January 2011, 14:04 »
I use a product called 'No more nails' when i stuck my number plates on :)
Offline Len
« Reply #6 on: 12 January 2011, 14:10 »
Those double sided sponge pads are good.
www.sas.org.uk
www.the-ace.org.uk
Offline Dan_GTi8v
« Reply #7 on: 12 January 2011, 15:49 »
the surrounds I have the bottom strip clips off and the plate slides in from the bottom, then clip the bottom back on and the plate is snug inside the surround
Doesn't really help you though im just bragging :P
  • Back in a Mk3...
« Reply #8 on: 12 January 2011, 15:52 »
same here..... I can't fit the golfgti frames as I don't currently own one  :lipsrsealed:
