Author Topic: Painted G60 arches...  (Read 4082 times)
Offline twistedblack69
  • Proud mk2 user and abuser
« on: 12 January 2011, 11:56 »
Looking at buying some arches that have been painted, but they haven't been smoothed, they're still textured, but my car isn't smoothed, so was gonna buy these and use some paint stripper on the paint, is this likely to damage the plastic, and is the texture likely to be left?
Re: Painted G60 arches...
« Reply #1 on: 12 January 2011, 12:09 »
I would guess that yes you would damage the plastic. pait stripper tends to melt plastic.
Not sure how you can get it off to be honest.
nige_s
« Reply #2 on: 12 January 2011, 12:15 »
They're ABS so might be resistant to some paint strippers.  Not sure which though, might be worth trying a hobby/model shop as I know from when I was a teen you could buy a particular paint stripper that shifted cellulose and enamel from plastic model kit parts, that could be suitable.
I'd be tempted to try a bit of nitromors on a small area as a test, don't leave it on for too long though.  Problem is that possibly the person who painted them sanded/keyed the plastic surface prior to painting so once/if you are successful at removing the paint the surface below might not be that presentable.
« Reply #3 on: 12 January 2011, 12:34 »
This is true...
Offline SoundillusioN
« Reply #4 on: 12 January 2011, 13:37 »
Dot 3 brake fluid. Just paint it on and leave for a bit. Then clean it off. Test first if possible, worked for me.  :wink:
Clean it very well if you intent to repaint.
« Reply #5 on: 12 January 2011, 16:35 »
No I wanted to put it on as normal textured plastic, but as above, under the paint could be a horror story.
nige_s
« Reply #6 on: 12 January 2011, 16:42 »
Brake fluid is a good idea
« Reply #7 on: 12 January 2011, 16:45 »
does dot 3 have a better paint removal spec than 4 or 5?  :grin:
you can get good plastic textured paint, which could sort you out if under the paint your arches are pap. alternatively theres a chap sellin a pair of front g60 arches on cgti
Offline Thom89
  • Looking for an "Icebreaker"
« Reply #8 on: 12 January 2011, 16:49 »
Blast it off with a steam cleaner, turned up tp max heat and pressure... never fails, and zero damage :cool:
Thom
Offline Sam
  • Sam I am
« Reply #9 on: 12 January 2011, 18:09 »
Tried the brake fluid technique on mine and it does nothing, left it on for half an hour with a radiator next to it  :shocked:
