Author Topic: Ridiculous Fuel Usage  (Read 1832 times)
Offline dannyd126
« on: 11 January 2011, 12:14 »
This is probably going to sound like a really amateur question to be asked by a mechanic but i just cant work it out.
But when my car runs on idle it uses a ridiculous amount of fuel, used twelve quids worth of fuel sat on idle for just under an hour while i was cleaning it. It aint head gasket or anything like that cause ive done all that recently. I first thought i might have a leak but ive checked the lines and the tank and its all fine.
It spits an unusual amount of water out of the exhaust when its sat on idle, i dont know if these are linked?
It does have a brand new cat on it which hasnt been ran in yet, which is probably screwed now due to the amount of water which has probably also flooded my 2nd lambda sensor, which is making it run really rich but didnt think it would be that bad.
FYI its a mk4 1.6 16v
Regards
Dan
A golf, Worlds finest
Offline AudiA8Quattro
Re: Ridiculous Fuel Usage
« Reply #1 on: 12 January 2011, 12:19 »
Try running VAG-com to see if you get any fault codes.
What are the emissions readings at idle? what was the last MOT like?
Offline dannyd126
« Reply #2 on: 12 January 2011, 19:28 »
The last MOT it nearly failed on emissions cos the cat was screwed but its got a brand new sports cat on it so its hard to say.
It runs really rich even on idle
Offline javalin
« Reply #3 on: 14 January 2011, 15:11 »
coolant temperature sensor.
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline dannyd126
« Reply #4 on: 15 January 2011, 22:18 »
the temp sensor is brand new mate, replaced it like 2 months ago
Offline rossbarry1
« Reply #5 on: 19 January 2011, 20:04 »
My 8v was doing this because of a dodgy connection on the air flow meter. Could be the same?
« Reply #6 on: 20 January 2011, 10:00 »
gen vag sensor? if not that could be it as the pattern ones are rubbish.
as above check vag-com, not just for faults but look at the measuring blocks. this can show you what ecu sees from ecu and inlet temp sensors, plus throttle angle etc.
does it take ages to warm up, if sop stat could be buggered. common fault on them, replace the stat housing too as there is liek a peg on there which the stat needs to push on, which often snaps off.
if all the above is ok, try disconnectign the lambda probe. if car is much better then you need a new one
Offline dannyd126
« Reply #7 on: 20 March 2011, 17:51 »
i think its cos of the map sensor, came up with a fault on obd-2 so im replacin it this weekend
