Author Topic: low engine temp  (Read 1365 times)
Offline jcook6788
low engine temp
« on: 11 January 2011, 11:56 »
Hey,
My car engine temperature is constantly low when the car is moving, the gauge can move off zero if im at a long traffic light but then will go back down.
When the engine does heat up its bang in the middle every time.
Has anyone else had this problem?
Re: low engine temp
« Reply #1 on: 11 January 2011, 12:16 »
What car ????
Could be thermostat
Offline jcook6788
Re: low engine temp
« Reply #2 on: 11 January 2011, 14:02 »
1.8t 1999.
Its just annoying as it effects the air con.
Morning + English winter = badbabbad
Like I said if its standing still it has no problem holding temperature perfectly?! and yes I no when you move you obviously have an amount of air cooling but its not like the engine is stone cold
Re: low engine temp
« Reply #3 on: 11 January 2011, 14:13 »
1.8t 1999.
I would post your question in the mk4 section but could be a thermostat / water pump problem
« Last Edit: 11 January 2011, 15:57 by Wayne »
Offline jcook6788
Re: low engine temp
« Reply #4 on: 11 January 2011, 14:24 »
Ok thanks I will do
