Author Topic: help need mk1 golf 1.8 20vt conversion  (Read 3943 times)
Offline travisreeve
« on: 10 January 2011, 18:34 »
ok guys im in need of pickin some of you brains advise will be realy greatfull
im doin the mk1 golf 1.8 20vt ( agu ) conversion
im using the 02A gearbox ( mk3 2.0L 16v box ) im goin to be purchasing a peloquin diff
as im spending out on the LSD im wanting to upgrade a few parts I.E clutch and fly wheel
does anyone know if the vr6 clutch will fit and the g60 flywheel
im not a mechanic so please go easy on me :)
Offline LazyLunatic
  • MK3 20VT Project
Re: help need mk1 golf 1.8 20vt conversion
« Reply #1 on: 10 January 2011, 18:47 »
VR6 Clutch Kit. LUK one is around £118 from EuroCarParts.
And a G60 flywheel. Same as the ones found on the 2.0 16v engines. If you have a crappy one I think VW give you £20 or so off a new one. Works out to be £100 for a new. Might have changed now though as that was well over a year ago now.
Offline travisreeve
« Reply #2 on: 10 January 2011, 19:03 »
sp basicaly they do fit :)
Offline LazyLunatic
  • MK3 20VT Project
« Reply #3 on: 10 January 2011, 22:19 »
Yep :)
I got them in my Mk3. I have a Sachs clutch not a LUK one but reading people's review's on them both, I'd say they are equally good, so which ever is cheapest for you I guess.
Its a common upgrade on the Mk4 too:
http://www.golfgtiforum.co.uk/index.php?topic=87775.0
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #4 on: 11 January 2011, 10:33 »
Yes a popular upgrade on the 1.8t I will be doing this when my clutch dies..
Offline Diamond Hell
  • Opinions я Us
« Reply #5 on: 11 January 2011, 11:14 »
Get somewhere to turn down the flywheel to 6kg and balance it - will make the engine rev much snappier.  You don't need a 9-10kg flywheel on a dinky little Golf1.
Offline LazyLunatic
  • MK3 20VT Project
« Reply #6 on: 11 January 2011, 13:50 »
Still better than the dual-mass bad boy! How much does that weigh compared to the G60 flywheel?
  • Opinions я Us
« Reply #7 on: 11 January 2011, 21:21 »
*slap*
The lightened single-mass is the best flywheel for this application.  :rolleyes:
No idea how much the dual-mass weighs.  Are you weighing it before or after it's fallen apart?!  :grin:
Offline travisreeve
« Reply #8 on: 11 January 2011, 22:07 »
beat you to it ;) already booked my flywheel in to be lightend  :drool:
LSD is on order as of next month :D then the gear box and engine will go back together and go in
QUESTION
having my flywheel lightend will this make it a pain in the arse for traffic hmmmmmmmmmmmmmmm
  • Opinions я Us
« Reply #9 on: 11 January 2011, 22:32 »
Not if the engine's properly managed.  It should be fine.
