Author Topic: help Door lock sticking!  (Read 2416 times)
Offline golfmissy
« on: 10 January 2011, 15:42 »
Can anyone advise me I have a 51 plate gt tdi. Recently on the drivers door, about 50% of time when i try and close the door the catch is still up on the lock position stopping the door from shutting. I can release it by holding open the handle on the inside and then poking it back down with my finger so it closes. Doesnt do it all the time but its flippin annoying when it does!
Any ideas.. am I going to need a whole new lock? Iver tried wd40.. waste of time.
Thanks in advance :-)
jamie16v
Re: help Door lock sticking!
« Reply #1 on: 10 January 2011, 18:45 »
door lock modue.. have a look in the maintenance and info section.
Offline Thom89
  • Looking for an "Icebreaker"
Re: Help door not closing all the time!
« Reply #2 on: 10 January 2011, 21:48 »
It sounds like your striker plate may have come loose, and is catching on the locking mechanism as you shut the door, flicking the "pawl" into the locked position...
Your striker plate is the shiny plate that is attached to the pillar, If I recall correctly, it is held on with 2x torx screws, check the plate to see if its worked loose, put the plate back to its original position, and retighten screws...
HTH
Thom
