Author Topic: Foam blowing out of air vents  (Read 3359 times)
Offline BiGUKG
  • Simples!
« on: 10 January 2011, 12:07 »
This happens quite a lot! I asked my older brother about it (who's had a couple of GTi's and re-built one!) and he said it's just the "flaps" inside? If they're going, does that explain that when I'm on the motorway, inside my car gets boiling hot, obviously where the engine is chucked heat back and it's coming through the vents, because there's nothing there to stop it doing so!
It doesn't matter to me at the moment, but just checking its nothing to worry about! Prob a common one?
http://www.vw-southeast.co.uk
"The community for enthusiasts and owners in the South East"
Re: Foam blowing out of air vents
« Reply #1 on: 10 January 2011, 12:16 »
yep all the flaps inside the airbox are covered in foam, once the foam goes the flaps become useless as they have lots of holes in!
Offline BiGUKG
  • Simples!
« Reply #2 on: 10 January 2011, 12:24 »
nothing to worry about then? Explains the "extra heat" inside on the motorway. Does it even when I turn all the heaters off. That'll be nice in the summer!
« Reply #3 on: 10 January 2011, 12:35 »
only worth worrying about if you are annoyed by the extra heat thing! if you take out the centre console and dash under trays, then remove all 4 vents plus the surrounds, you can remove the side vent piping and the distribution bit on the front of the airbox. from there you might just be able to reach in thru the hole on the front to repair the heat flap, but it will be a pain in the arse thats for sure.
if not you may have to remove the blower housing from the side, undo the nut behind the header tank in the bay plus a plastic nut near the a pillar and finally lever off the clips that hold the blower to the centre airbox. then i think you can get to the cold/hot flap thru there.
tbh might be easier to have the whole airbox assy off together, 2 more nuts in the engine bay plus the 2 coolant pipes on the matrix. put a couple corks in the outlets so you dont get coolant all over the carpets.
Offline rob.043
« Reply #4 on: 10 January 2011, 12:35 »
At least your heater is in good order!
If you feel like fixing the vents come summer, its the heater box you need to remove, as per the matrix removal guides (as RJ has said above).
I used some of this stuff to re-cover my flaps (ahem), seems to be working well so far:
http://cgi.ebay.co.uk/Neoprene-sponge-rubber-adhesive-strip-75mm-x-3mm-x-10m-/170586473431?pt=UK_DIY_Materials_Plumbing_MJ&hash=item27b7bf03d7
« Last Edit: 10 January 2011, 12:37 by rob.043 »
Offline BiGUKG
  • Simples!
« Reply #5 on: 10 January 2011, 12:43 »
Yeah might be a job worthwhile in the summer. Clutch comes first at the moment though, the thrust bearing is getting bad! I know its not major but I'd rather be sweating my n*ts of than listening to that!
Will add it to the list, cheers for the replies. appreciate it!
Offline foxyjay
  • Aged but not old
« Reply #6 on: 11 January 2011, 22:11 »
Mine's just same..........ignoring it  :shocked:
I'd like to thank my father for teaching me about shaving, about women, and about shaving women.
Offline TreadGingerly
« Reply #7 on: 11 January 2011, 23:30 »
I'd like some of your 'extra heat' in my mk2 icebox.
Offline BiGUKG
  • Simples!
« Reply #8 on: 12 January 2011, 09:42 »
Don't think its major, not high on my list at the moment.
Oh, heaters not working then? Bet thats comfortable this time of year!
