Author Topic: Coolent Temp Sensor  (Read 1500 times)
Offline wpisme823
Coolent Temp Sensor
« on: 10 January 2011, 10:53 »
Hi,
Just a quick question, my car (golf mk3 1.4 se) is running rich so im about to buy a new coolent temp sensor to see if it cures it.
If the temperature gauge on the dashboard is working fine does this mean the temp sensor is ok??
Just want to make sure before i spend 14 quid on it
cheers
will
Offline Deano2711
  • 1992 VR6
Re: Coolent Temp Sensor
« Reply #1 on: 10 January 2011, 10:56 »
I may be wrong but I do believe the coolant temp sensor would not have anything to do with your car running rich. Also if the temp guage is working ok the sensor should be fine.
Offline wpisme823
« Reply #2 on: 10 January 2011, 11:00 »
ok cheers, yeah after i rang up the part shop i suddenly realized if the gauge is working it should be fine!
Do you have any ideas what could be making it run rich, the smell of petrol is strong from the exhaust when running hot or cold. So i assumed it was the choke holding on thinking the engine was cold at all times.
« Last Edit: 10 January 2011, 11:03 by wpisme823 »
« Reply #3 on: 10 January 2011, 11:35 »
the coolant temp sensor for dash is separate to the one for the ecu. they may be in the same sensor housing, but internally there are 2 different sensors
Offline javalin
« Reply #4 on: 10 January 2011, 11:38 »
the "choke" is actually extra fueling (i.e. longer injector opening times) which is controlled by the ECU based on the engine temp reported by the coolant temp sensor.  As the engine warms up the fueling is decreased.  Its a single part with two temperature dependant resistors in it - one runs the dash and the other reports to the ECU.
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline wpisme823
« Reply #5 on: 10 January 2011, 11:47 »
thank you for the advice. (my knowledge of engines only stretches to small motorbikes!)
I will purchase the temp sensor now and see if it sorts it out.
im running at about 15mpg at all times at the moment so i am desperate to sort it out!
« Reply #6 on: 10 January 2011, 12:10 »
Yes it will do in some respects as it controls the cold start map so as it warms up it cuts back the fueling
Offline Bellend
« Reply #7 on: 10 January 2011, 12:12 »
Mine was running rough. Changed the yellow coolant sensor and all is good.
However the thermostat has gone now I'm driving it. So on a run it cools down and it runs dodgy until it sits at the same temperature for a while.
I'd change it, they aren't expensive.
Where all my moneys went.
