Author Topic: Tidying up an engine bay  (Read 11388 times)
Offline tech1889
  • Mk2 GTI FTW !!
Re: Tidying up an engine bay
« Reply #30 on: 11 January 2011, 20:59 »
would there be any way round this ?? maybe using a new loom so that the wires are of better condition ??
Offline clipperjay
« Reply #31 on: 11 January 2011, 21:12 »
Well thats part of the problem with 20 year old wires adding large sound systems and increasing amp usage.
Personaly I would try and speperate the lot into positive, neutral and grounds then make sure they are water tight most drain holes are in the chassis legs which don't help, plus water in the rad area from forced air water on the front of the car! IMO you can do it properly but most people won't due to time and effort involved. I have seen bays that have false sides back and sides so they create cavities that are water tight (EXPENSIVE) and those boys are high end as they really don't want any wires to be seen and also delete car componets and relocate for minimalistic bays. With enough money you can do anything well  :grin:
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #32 on: 11 January 2011, 21:14 »
I might try for a bit of a beginners smooth'ish bay... will relocate what i can.. will hide a few wires.. im not gona get anal about as i like to access my wires when something goes wrong lool.. just smarter than OEM if that makes sense ??
Offline Sam
  • Sam I am
« Reply #33 on: 14 January 2011, 10:49 »
OOOoo here is a good idea, see how the washer bottle and expansion tank have been sprayed black  :smiley:
Offline cняis
« Reply #34 on: 14 January 2011, 14:26 »
i think i'd rather be able to check coolant level  :laugh:
Offline Sam
  • Sam I am
« Reply #35 on: 14 January 2011, 14:32 »
You could always mask a thin line up one side?
Offline messenjah
« Reply #36 on: 14 January 2011, 15:48 »
or replace the level sensor so you know it works and learn to check the engine temp periodically
Offline cняis
« Reply #37 on: 14 January 2011, 18:27 »
the sensor wont read any temp if there's no coolant in the system...  :rolleyes: :lipsrsealed: :lipsrsealed:
Offline messenjah
« Reply #38 on: 14 January 2011, 19:02 »
but the level sensor will flash the coolant warning light if theres no coolant in it
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #39 on: 14 January 2011, 20:00 »
sensor = go wrong
