Author Topic: Tidying up an engine bay  (Read 11385 times)
Offline madmanluke
Re: Tidying up an engine bay
« Reply #10 on: 10 January 2011, 21:56 »
i like the idea of the power steering bottle there Ben.
Offline cняis
« Reply #11 on: 10 January 2011, 21:59 »
funnel required for refilling!  :wink:
Offline madmanluke
« Reply #12 on: 10 January 2011, 22:04 »
i bet :)
Cant help but think of a different bottle that could be used with a filler neck that could come out the side of the wing so you cant see the actual bottle its self
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #13 on: 10 January 2011, 22:07 »
so move battery to boot and leave a bit to jump start hows that work.. im not taking the piss just curious.. and AA van i once saw had a big bullet connector type thing on front of his van and had special jump leads.. can you just do this and hide the jump lead points ??
Offline cняis
« Reply #14 on: 10 January 2011, 22:24 »
cable block is on my inner strut:
You lift the cap (marked with the big "+" symbol) and there's a big metal jump point under there  :smiley:
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #15 on: 10 January 2011, 22:27 »
ohh sorry missed that.. looks nice..
Offline Benrevs
« Reply #16 on: 11 January 2011, 14:49 »
The majority of BMW's have boot located batteries with a big chunky 20mm thick cable running through the car to the engine bay. Scrapyard is your friend on that. The positive box as in Chris's picture is also from the beemer.  I also put the washer bottle in the boot, it was a small one used for the BMW's headlight washers. The good thing with engine bays is there are no rules so use your imagination!!
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #17 on: 11 January 2011, 17:19 »
So you have positive in the bay.. where do you earth out to ??
And instead of a beemer cable.. cant you just buy a heavy duty cable and make it up yourself ??
Offline Sam
  • Sam I am
« Reply #18 on: 11 January 2011, 17:22 »
Well surely you just earth out in the boot on a really shot lead, perhaps to the chassis? Then in the bay you can earth out to wherever your want
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #19 on: 11 January 2011, 17:37 »
i dont like the sound of that  :grin:
