Author Topic: vw spring markings  (Read 1372 times)
Offline richard s
vw spring markings
« on: 09 January 2011, 17:54 »
i have just swapped a front spring and shocker over on my passat as a spring snapped on new years eve
the spring i removed has one white mark and three brown marks and the spring i have fitted has one white mark and two brown marks
does anyone know what the markings stand for
Re: vw spring markings
« Reply #1 on: 09 January 2011, 23:53 »
The markings are so you know the spec of spring being fitted, different engines or sport pack etc.  :smiley:
Offline richard s
« Reply #2 on: 10 January 2011, 20:04 »
one car is a 20v 1.8t sport and the other one a 20v 1.8 sport which is why i expected them to be the same springs. then i saw the different markings and wondered what the difference was between the two
« Reply #3 on: 10 January 2011, 20:49 »
I would guess heavier duty maybe, the turbo will not be adding much so should be ok to use as a pair however.
« Last Edit: 10 January 2011, 20:51 by Wayne »
Offline richard s
« Reply #4 on: 12 January 2011, 20:58 »
it is the using them as a pair im having a problem with. my car has the 1 white and 3 brown stripes as standard but as i had a snapped spring i didnt want to strip the shocker down to change a spring so i got a strut from a scrapper with 1 white and 2 brown stripes. ideally i would like to have both springs the same but i dont want to pay £60 for 2 second hand springs
« Reply #5 on: 12 January 2011, 22:08 »
It always better to fit shocks and springs in pairs.
