Author Topic: Im guessing this is the correct method?  (Read 2034 times)
Offline JDM82
« on: 09 January 2011, 16:11 »
Right then Ive give my car a proper clean using the correct method.
After the washing I used a polish then I used a sealant then finally I waxed.
Im guessing the next time I wash my car it'll be a simple wash dry and quick detailing spray????
Surely the polish, sealant and wax is a once a month or so process?
Thanks for reading!
GOLF GTi - The legendary hot hatch
Offline Dan J
Re: Im guessing this is the correct method?
« Reply #1 on: 09 January 2011, 16:51 »
if you've polished it well and so on then yes its just a case of wash and a quick spritz over with either qd of a gloss enhancer, you can top up with a layer of wax if you wish to afetr washing but its not essential.
after about 4 to 6 months re-clay if needed and polish if required then repeat the process.
keep ontop of your washing and it will help you in the long run :wink:
