Author Topic: gti 8v mpg problem  (Read 1382 times)
Offline bauer
gti 8v mpg problem
« on: 07 January 2011, 19:58 »
ive had my car for about 4 years but recently due to unemployment (back unemployed again, damn recession) its been off the road for about 18 months, any 4 months ago i decided to get her mot'd and get her running again, all was fine except that i thought it used to be more economical than it seemed to be now (i put it down to petrol prices etc) but over the last month i have been calculating what i have been getting (myself not the false computer which always says around 28-31) and ive been getting between 15 - 18 to the gallon, i used to get about 25-35 if i remember correctly
does anyone know where to start with trying to find out whats causing her to gulp it down? cheers  :cool:
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: gti 8v mpg problem
« Reply #1 on: 07 January 2011, 20:23 »
as it's been off the road for a long time it'll probably benefit from a good service for starters. Check the brakes aren't binding slighty, tyre pressures.
Is the car running properly? does it warm up correctly?
Also bear in mind that it'll be less economical in this recent freezing weather.
Offline bauer
« Reply #2 on: 07 January 2011, 20:37 »
thanks for your reply
yeah ill get it serviced, tyre pressures are fine, the breaks aint binding, if im honest with you it doesnt seem to be running right, i cant put my finger on what it is, the power (or lack of it :grin:) is about the same, although it feels like its higher up the revs when im just doing 70 on a motorway etc, seems louder? it is warming up ok
Offline bauer
« Reply #3 on: 07 January 2011, 21:31 »
another thing ive noticed is it can be slightly juddery when accelerating quite hard??
Offline Seanl
« Reply #4 on: 08 January 2011, 18:55 »
Possible MAF problem. That would explain the juddery acceleration and rough running, and it will be running rich if it's not detecting enough air flow so that would increase fuel consumption.
Offline Deano2711
  • 1992 VR6
« Reply #5 on: 08 January 2011, 19:03 »
Give it a good service, clean the throttle body and change the air filter. All reasonably cheap enough and easy enough to do.
Offline bauer
« Reply #6 on: 11 January 2011, 11:11 »
cheers fella's. another thing i forgot to mention is sometimes it wont start first time, i have to turn her over 3 times.
and when idling it feels a bit rough, ill give her a service anway thanks lads
Offline Deano2711
  • 1992 VR6
« Reply #7 on: 11 January 2011, 11:32 »
Rough idling could be down to the dirty throttle body I suggested. Whip that off and give it a good clean and check the breaher hoses for wear and tear or damage. Takes about an hour to clean the throttle body (properly) and gies good returns  :wink:
Offline bauer
« Reply #8 on: 11 January 2011, 11:36 »
cheers mate, ill give that a go also :smiley:
