Hi all am new here, I have just started ownership of an 8v gti which needs a little work to get bit back to its former glory. One of the jobs that needs doing is the headlights. If you look at the front of the car square on the o/s headlight appears to be slightly out of line. I have measured the gap between the headlight and the wing on both sides. The gap between headlight and wing on the o/s is 4mm in the top corner and 4mm in the bottom corner. The gap between wing and headlight on the n/s is 4mm in the top corner closing to 2mm in the bottom corner! Any help on how to solve this would be greatly appreciated. Dale
(Also i want to start mk3 project thread, do you need to have minimum ammount of posts to send pm to jv?)
