Author Topic: Testing battery and alternator  (Read 1762 times)
Offline Shady Pioneer
  • graphic designer.
« on: 07 January 2011, 12:43 »
So my car died again 2 already this year. I had a new battery a little over a couple of months ago, and it seemed to work fine and do the trick, but as of the late it's been struggling to start. I've gone and got myself a tester, but where and how do I use it? Don't want to go killing myself.
I'm hoping it's the battery that's at fault as that can then be replaced for free, however if it's the alternator I don't want to be shelling out £70+ on a new one.
Any help?
Offline LowlifeDubber
Re: Testing battery and alternator
« Reply #1 on: 07 January 2011, 13:16 »
Set your multimeter to 12v put it on the battery.You should get a reading of about 11.5-12.5v now leave the tester on and start the car up.
Now the voltage should go up to about 14.4v give or take.Much more and your alternator is overcharging.No move at all and it's not putting a charge in.
  • graphic designer.
« Reply #2 on: 07 January 2011, 13:28 »
Thanks for the info bud. How would I know if the battery is at fault though?
« Reply #3 on: 07 January 2011, 13:43 »
With the engine off put your tester on the battery,now turn everything on,in the car.Lights,heater,wipers demister etc.Then watch to see how far it drops and how fast.
If it starts dropping pretty rapidly to the point where it goes under 10v then it's likely that its your battery.
I tend to drive down to the local tyre place(not kwik sh!t etc) and ask them to do a drop test on your battery,its a similar test,where they put a load on the battery and see how far it drops.
It's always free for the check in 99% of the places too. :cool:
  • graphic designer.
« Reply #4 on: 07 January 2011, 13:48 »
Ace. Cheers bud. I'll try the tests this eve and see what I get as a result. Still hoping it's the battery. :grin:
Offline VR6_Wherry
« Reply #5 on: 07 January 2011, 13:57 »
It could be that something is on when you turn the car off.. Thus draining the battery overnight..
« Reply #6 on: 07 January 2011, 14:39 »
Id rather it be the alternator.Easy to change and a second hand one is cheaper than a good battery :grin:
  • graphic designer.
« Reply #7 on: 07 January 2011, 14:46 »
2 year warranty and it's only 2 months old. :evil:
« Reply #8 on: 07 January 2011, 15:28 »
Oooops,missed that :grin:
Yep lets hope your battery is shagged then :evil:
Offline Bellend
« Reply #9 on: 07 January 2011, 17:53 »
Sure it's not a starter?
If you get it checked out I have a spare 70A alternator. If it's correct ampage which it may not be I'll post it to you and you can try it out. If it sorts it it's yours.
Where all my moneys went.
