Author Topic: Missing K-Jet Adjustment Screw!  (Read 7547 times)
Offline golfmk4owner
« on: 07 January 2011, 11:13 »
Hi guys, my 16v has a very rich smelling mixture, and my mechanic pointed out that the mixture adjustment screw is actually gone!
I really need this as you can imagine, and cant just go and buy one, does anybody have any ideas?
Or is there anybody with any spare metering heads (mk2 2 16v KR code) that i could buy?
Im stressing about this  :cry:
2005 GT TDI 140 - Standard as F@k
Re: Missing K-Jet Adjustment Screw!
« Reply #1 on: 07 January 2011, 15:06 »
Ok guys no replies so can somebody tell me if this screw is the same as the mk1? Because there are some on mk1 metering heads on ebay! cheers
Offline Horney
« Reply #2 on: 07 January 2011, 15:25 »
MKI's were all 8v and the metering heads are different although they might have the same adjustment screw. Your engine is a KR which was also fitted to 1.8 16v corrados, 1.8 16v B3 Passats those could be other avenues for sourcing a replacement. Have you tried a Bosch injection specialist or even VW for a replacement?
nick
Offline UKjarvis
« Reply #3 on: 07 January 2011, 16:13 »
I have 2 spare screws from 1.8 8v's not sure if there the same, but your welcome to them.
Offline Mew
« Reply #4 on: 07 January 2011, 16:16 »
Is it definitely gone? Do you/your mechanic know that it's quite deep within the metering head so you need a reasonably long hex key?
Offline Sam
  • Sam I am
« Reply #5 on: 07 January 2011, 17:25 »
Yer was gonna say, you cant just look at it and say its gone, its almost impossible to see. It does just look like an empty hole
« Reply #6 on: 07 January 2011, 17:35 »
Ah, hmm. Well he could be mistaken in that case, but tell me if these pics look right cos theres two hole, and i would like to know what each one is for
Hole 1 (which i think is the CO adjustment)
And hole 2, which is just behind it:
Thanks so far guys!!
« Reply #7 on: 07 January 2011, 18:00 »
Also, when it comes to adjusting the CO, can anybody remember which way leans and which way richens? thanks
Offline Mew
« Reply #9 on: 07 January 2011, 18:44 »
Nice thread! But now another dillema... that guide says that 16v's run best at 2%, which my mechanic said it was when he tested it!
So any ideas why it smells sooo rich and smokes white at idle? I know everyone will say head gasket but the water / oil are both fine. Theres no blue smoke, just white smoke, and its worst at idle and eases off when driving. It isnt just condensation neither!
