Author Topic: Diesel particulates  (Read 18041 times)
Offline Egbutt Wash
Diesel particulates
« on: 07 January 2011, 01:13 »
A serious question.
With particulates in mind, is it right to drive a diesel VW or any diesels?
« Last Edit: 08 January 2011, 10:37 by The Doc »
Currently digging a bunker.
Offline The Doc
  • E63s Estate - Vito Sport
Re: Why go smoggy?
« Reply #1 on: 07 January 2011, 14:49 »
Great topical posts but all MK6 golfs have DPF's, a diesel particulate filter that as the name suggests filters out most of the nasty particulates and also reduces the size of them.
« Last Edit: 08 January 2011, 10:39 by The Doc »
Offline mac7
Re: Why go smoggy?
« Reply #2 on: 07 January 2011, 16:33 »
Great topical posts but all MK6 gold have DPF's, a diesel particulate filter that as the name suggests filters out the nasty particulates that cause all of the problems mentioned.
DPF catches some of the particulate, but not all of it. When you consider the increase in the number of diesel cars on the roads, I reckon you're back to square one.
Golf R
Offline Agreeable Slick
  • Unit
Re: Why go smoggy?
« Reply #3 on: 07 January 2011, 17:06 »
You do realise just how much particulate they filter don't you.
Current emissions law mean less than 0.02g/kWh is allowed to pass in order for the car to be released.
Offline mac7
Re: Why go smoggy?
« Reply #4 on: 07 January 2011, 21:05 »
Yeah, 0.02 sounds like a really small amount, until you look at the Euro 3 figures - it was 0.10g/kwh before DPF's were introduced, so it's 1/5th what it used to be. Ten years ago there was one diesel car in my road, now there's at least seven...
You might be able to answer another question for me though. When the DPF regenerates, by burning off the 'soot' from the filter, what exactly are the products of that (combustion?) process and where do they go?
Golf R
Offline The Doc
Re: Diesel particulates
« Reply #5 on: 08 January 2011, 10:42 »
They are stored then burned in the dpf which reduces them by over 90% then ejected through the exhaust.
  • Unit
« Reply #6 on: 08 January 2011, 14:11 »
Usual products of combustion, DPF is typically before the other parts of the cat, so like doc says; regen takes place and burns off the PM, thus it produces carbon monoxide, CO2 and HC
Depending on if the exhaust has a SCR system or chemical reduction, then the emissions are only CO2 and water.
These are then caught/cleaned up by the latter stages of the cat.
Offline Keithuk
« Reply #7 on: 21 January 2011, 18:56 »
2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
R32.
« Reply #8 on: 28 January 2011, 18:59 »
I love modern diesels  :wink:
« Last Edit: 28 January 2011, 21:32 by The Doc »
Offline mac7
« Reply #9 on: 28 January 2011, 21:43 »
Diesel particulate filter (DPF)  :wink:
Good link - thanks Keith. So the DPF fills up over 120,000 miles or so until a second/third/fifth owner pays a back-street mechanic to tip it all out into the atmosphere anyway... :grin:
Golf R
