Author Topic: help with my mates car...  (Read 1462 times)
Offline Wazzzer
  • Golf GTI 1.8T AGU
« on: 06 January 2011, 19:21 »
Hi people, I need your help.
I'm due to look at my mates mk3 tomorrow to try and cure his running probs but I would like an idea of where to start...
Here's his description
Right, initially the revs would dive when you dip the clutch, which was only a problem when coming to a stop, as the car would die. Now it's evolved into erratic revs, loss of power, and cutting out. It seems to be ok when cold, and starts to manifest after 10 min+ of driving. My uneducated guess is something to do with the airflow. I've heard there's a valve that can get gummed up, which can cause issues. But I wonder if it's airflow meter playing up - although I'd have thought the meter would cause issues from cold?
Any ideas?
Offline LowlifeDubber
Re: help with my mates car...
« Reply #1 on: 06 January 2011, 19:53 »
What engine would be a good start :wink:
Offline *tell*
« Reply #2 on: 06 January 2011, 20:32 »
if its a mk3 i would start with scanning it.
Offline dom
  • Back in a Mk4
« Reply #3 on: 06 January 2011, 20:52 »
Any ideas?
This is a classic sign of a dirty throttle body, giving it a really good clean with some carb cleaner would be a good start  :smiley:
Offline spunkymonkey
  • Tepidly moist! That's what that is!
« Reply #4 on: 06 January 2011, 21:08 »
Ecu temp switch maybe if its only running rough when warm.
Offline tweed
« Reply #5 on: 06 January 2011, 21:23 »
+1
Offline Wazzzer
  • Golf GTI 1.8T AGU
« Reply #6 on: 07 January 2011, 07:12 »
Sorry guys MK3 8v.
I'll give the throttle body a clean then, I've got vag com so will give it a scan too. Temp sender sounds fimiliar from the mk4 so will look there too.
Ill let you know how it goes
Offline Wazzzer
  • Golf GTI 1.8T AGU
« Reply #7 on: 08 January 2011, 12:47 »
Quick update, went out in it last night and nothing went wrong lol
But I did notice the revs dropping when coming to a stop if you dip the clutch. Also checked with VAG COM and nothing on there. Should the ECU take around 5 secs to recognise that the MAF has been plugged back in?
Any more input would be appreciated, we're stumped. 2.0 GTI 8V
