Golf mk4
Wazzzer
k03/s intake OD
Topic: k03/s intake OD (Read 1937 times)
jamie16v
Guest
k03/s intake OD
06 January 2011, 10:00 »
anyone know the outer diameter of a k03/s intake port?
cheers, jamie.
MaXXeH
Golf MK5 GTI
Re: k03/s intake OD
06 January 2011, 12:46 »
Ko3 - 97-2000
COMPRESSOR WHEEL
Inducer: 33.6mm
Exducer: 46mm
Tip height: 3.7mm
TURBINE WHEEL
Inducer: 45mm
Exducer: 38mm
Tip height: 6.8mm
Blades: 11
Ko3S - 01+
COMPRESSOR WHEEL
Inducer: 38mm
Exducer: 51mm
Tip height: 4.4mm
TURBINE WHEEL
Inducer: 45mm
Exducer: 38mm
Tip height: 6.8mm
Blades: 11
Ko4-015
COMPRESSOR WHEEL
Inducer: 35mm
Exducer: 50mm
Tip height: 3.7mm
TURBINE WHEEL
Inducer: 50mm
Exducer: 42mm
Tip height: 6.4mm
Blades: 11
jamie16v
Guest
Re: k03/s intake OD
06 January 2011, 13:10 »
nah mate, i mean the rim of the turbo, the bit the tip fits onto.. so the measurement i am after is the outer diameter of the turbo rim or the inner diameter of the TIP (turbo side)
Dave_IOW
Forum addict
Re: k03/s intake OD
06 January 2011, 17:39 »
45mm
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
jamie16v
Guest
Re: k03/s intake OD
06 January 2011, 20:23 »
legend!
Golf mk4
Wazzzer
k03/s intake OD
