Author Topic: possible rocker cover failiure  (Read 1840 times)
Offline Cory
« on: 05 January 2011, 12:34 »
i have a 1.6 driver, and ive found oil running down onto the exhaust manifold, and smoking.
im guessing its coming from a worn rocker cover gasket?
« Last Edit: 05 January 2011, 12:50 by Cory »
Re: possible rocker cover failiure
« Reply #1 on: 05 January 2011, 13:31 »
Sounds like it yes, easy enough to replace.
Offline Sam
  • Sam I am
« Reply #2 on: 05 January 2011, 18:19 »
Yer sounds like it is mate, bought one from gsf for..........£3 so i wouldnt worry. Just make sure you put everything back to where it came from  :smiley:
Offline Cory
« Reply #3 on: 06 January 2011, 12:44 »
already got a full gasket kit. also. can anyone think of where any oil might be sitting? as i have smoke coming from under the exhaust manifold somewhere, from an oil leak the orher day and want to clean it up.
Offline Sam
  • Sam I am
« Reply #4 on: 06 January 2011, 13:18 »
Its often easier to spot where oil is comming from if you get under the engine rather than on top
Offline Agreeable Slick
  • Unit
« Reply #5 on: 06 January 2011, 13:40 »
The oil will undoubtedly be absorbed slightly into all of the accummulated crap on the outside of the engine as well, so short of gunking the engine and steaming it off, it will continue to smoke until it has burnt off.
Just keep an eye on it. Worst case, get a wire brush and do to work on the engine block giving it a clean up.
Offline Cory
« Reply #6 on: 06 January 2011, 22:55 »
cheers guys. do you know what colour oil pressure switch a 1.6 carb enging should have. do GTI's have grey ones?
Offline berni29
« Reply #7 on: 06 January 2011, 23:54 »
Hi
Use a mk3 rubber gasket. Much better than the Mk2 one. It should come with the correct studs.
Berni
Offline tony_ack
« Reply #8 on: 07 January 2011, 18:25 »
+1
Pressure Washer... just cover the dizzy and plugs
1992 VW Golf MK2 GTI
1995 VW Corrado VR6
