Author Topic: Rocker Cover  (Read 1181 times)
Offline greggyboy
Rocker Cover
« on: 05 January 2011, 10:05 »
Hi, replaced my rocker cover on 1.6 driver mk2. Rubber gasket. it was still leaking after being replaced. I took it to a vw garage thinking i have done it wrong somehow and its still leaking from the same spot, back corner by cam belt. I believe that this maybe causing the whinning from the cambelt due to a little bit of oil leaking onto it.
Any advice.
Greg.
Offline Steve_B
Re: Rocker Cover
« Reply #1 on: 05 January 2011, 20:57 »
If it's a rubber gasket you need the studs that don't have a shoulder on them. Maybe one of your studs is the wrong type?
Offline berni29
Re: Rocker Cover
« Reply #2 on: 06 January 2011, 06:55 »
Hi
When I changed mine I used a mk3 one which is rubber, and it came with new studs........ The cork one I originally tried was hopeless.
Berni
