Author Topic: 8v GTI AGG Will not start  (Read 2481 times)
Re: 8v GTI AGG Will not start
« Reply #10 on: 05 January 2011, 11:43 »
I'll make note of that. thanks.
I've just took off the HT lead from the coil to the dizzy and blew the WD40 i sprayed on it earlier....
Started the car and whey hey its started but struggling to keep running.... few revs and its stable...... took for a spin and still ok just left running for 10 mins in idle to hopefully dry out the moisture....
I'm ashuming my coil is ok then?? and just had a damp problem do u think???
Yes sounds like it.
Offline christomk3gti
« Reply #11 on: 05 January 2011, 11:52 »
cheers peeps
I took the dizzy cap off and sprayed wd40 in there and cleaned that too.... could do with it changing really coz the points look worn. but soooo happy its working again :))
thanks as usual :)
Black 8v GTI............. Whats a Waffle Valve?
Offline javalin
« Reply #12 on: 05 January 2011, 11:58 »
worth doing, cheap and easy and makes a big difference.
J
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
« Reply #13 on: 05 January 2011, 12:10 »
i will do :)
I'll keep this thread posted with a completed one hopefully :)
« Reply #14 on: 10 January 2011, 19:38 »
a week on and not a problem :)
changing dizzy cap, rotor arm and spark plugs at the weekend.
Offline stow1985
  • 'when im cleaning winders'
« Reply #15 on: 16 January 2011, 20:06 »
Glad i found this thread,
ive been having this problem too, ive read what people have said, so il crack on his week,
thanks al!
« Reply #16 on: 21 January 2011, 19:58 »
Mines all fine and dandy now :)
Offline vw_gti
« Reply #17 on: 22 January 2011, 22:38 »
Mine had a similar problem where i couldnt get it to start. turned out the plastic slot in the rotor arm had snapped so obviously it wasn't spinning as it should.
The cap and arm also had a lot of buildup on them so replaced both that and the cap and its running better than it was before the problem even came about. definitely worth changing them. Cost me under a tenner.
