Author Topic: ((((vr6 stock to vr6 track))))  (Read 96904 times)
Offline mmaattyyg
  • i need anger management as i dont take advice well
i need anger management as i dont take advise well ......
Offline mmaattyyg
Re: ((((vr6 stock to vr6 track))))
« Reply #201 on: 21 January 2011, 00:42 »
one seat in !!!!
« Reply #202 on: 21 January 2011, 11:50 »
Cracking work, not sure on those seat mounting brackets  :undecided:
Offline sharki786
  • GOT BOOST??
« Reply #203 on: 21 January 2011, 11:57 »
NIIIIIIIIIIIIIIIICEEE  :cool: bet that must be quick without all that weight. have you took it to one of them places where it weights the car before and after? sorry just flicked through the pics. looks good,
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline Diamond Hell
  • Opinions я Us
« Reply #204 on: 21 January 2011, 13:11 »
Ditto - should be on tubes that run across from sill to tunnel rather than on spindly little uprights that are bolted through the floor.
Obviously, you've fitted reinforcing plates under the floor, right?  To ensure the seat won't just tear out, yeah?
At the moment this project looks like it's being completed by someone who's seen a rollcage in a racing car on the telly once, rather than bothered researching what they're doing.
Did you get any specification for the 'mild steel' tubing you're now using to secure your harnesses to, or have you actually just used scaffolding bar?
Offline mmaattyyg
« Reply #205 on: 21 January 2011, 18:41 »
new engine and gearbox mounts are on ( my hands are cut to f**k )
also think ive sussed out why my temp runs at 70 instead of 90 degress ! the auxiliary water pump is f**ked !!!! any ideas where to get one as they are not a common part,  from what ive read only the 1992 vr6 and simmilar models had this AUXILIARY water pump !?!?!?
Offline mmaattyyg
« Reply #206 on: 21 January 2011, 18:43 »
not yet mate but i will do ! if i had to guess i would say ive taken out approx 100kg, i have filled up a ton bag with the parts ive taken off the car and now i can bearly lift the bag
Offline mmaattyyg
« Reply #207 on: 21 January 2011, 18:45 »
alright wayne ! the seat was a rush job to get in as i needed to drive the car somewhere to get something done, and didnt have the old seats ! but the seat subframe/braket will be rectified properly and rienforced ! watch this space !!!!!!!!!
Offline The Mighty Elvi
  • I'm better than you today.
« Reply #208 on: 21 January 2011, 20:31 »
+1 on the seat mounts.  Dear God!  Slam the anchors on and....PING!
Offline SoundillusioN
« Reply #209 on: 21 January 2011, 21:42 »
Looking good, i'm not saying anything negative as thats already covered.   No answer to the rear bar question?....... Seems it's going to be pretty tidy looking inside..
