Author Topic: banging noise from backend  (Read 2904 times)
Offline Walkerboy
« on: 04 January 2011, 21:38 »
since the snow has hit ive been hearing a banging noise from the rear end,its not the exhaust or the subframe bushes so......
any ideas ppl???????
« Last Edit: 04 January 2011, 21:40 by Walkerboy »
Re: banging noise from backend
« Reply #1 on: 05 January 2011, 00:15 »
Rear top mounts or beam bushes.
Offline LazyLunatic
  • MK3 20VT Project
« Reply #2 on: 05 January 2011, 01:27 »
I's swing more towards rear top mounts, especially if its on coilovers.
Could be an exhaust heat shield. Its quite a common thing.
Offline MotorPsycho
  • I drive a 2000bhp dragster, so what ;)
« Reply #3 on: 05 January 2011, 08:01 »
If the back end sways on bumps/corners then its beam bushes
If its just a banging I'd say top mounts
1983 mk1, 2.0, TSR pack C head, Eaton M45 - work in progress
1990 mk2 GTD, boost, fuel, soot
16v GTi mk3; chilli red, 16" Audi Speedlines, coilies
1934 Ford Dragster, 200mph in 6 seconds.
Offline dom
  • Back in a Mk4
« Reply #4 on: 05 January 2011, 11:45 »
Let the male escort out of the boot?  :lipsrsealed:
Offline GrandMstRamRod
« Reply #5 on: 05 January 2011, 11:47 »
hahaha that just reminded me to take mine out my boot, sh!t hope he is ok, sorry bout the problem dude!
« Reply #6 on: 05 January 2011, 11:49 »
Dom you worry me  :grin:
nige_s
« Reply #7 on: 05 January 2011, 12:02 »
Double check exhaust, if it's lowered the clearance between it and the rear axle/beam is greatly reduced.  Wiggling it with your hand might not be enough to induce contact.  Follow the exhaust with you hand as it kicks up over the beam if clearance between the two is about less than 20mm then they will make contact when the car is travelling.
Offline LazyLunatic
  • MK3 20VT Project
« Reply #8 on: 05 January 2011, 14:49 »
My zaust rattles on the beam on idle when I got more 2 more people in the car. Annoying.
Offline VR6_Wherry
« Reply #9 on: 05 January 2011, 14:55 »
Me too, that is actually Dom!!  :grin: :grin: :grin: :kiss:
