Author Topic: Power steering fault?  (Read 14267 times)
Offline sundaydriver
« on: 04 January 2011, 18:13 »
My power steering lately feels heavier than usual, i thought at first it was just me due to driving in the snow but now the snow's gone it feels even heavier and i'm down on MPG. On a usual run to work i used to get around 36MPG but now im getting on average 30-31MPG
I've checked the tyre pressure's and they seem OK (33psi all round) but i did have a flat battery a couple of weeks ago and maybe that has something to do with it.
2012 Golf R, APR STAGE 2+, BCS power valve TB exhaust, loba HPFP, evoms intake, Rising blue, 19" Talladegas -BMW M2
Offline R32UK
Re: Power steering fault?
« Reply #1 on: 04 January 2011, 18:14 »
33psi???  :shocked: :shocked:
bit on the low side :huh:
Offline Phil1980
« Reply #2 on: 04 January 2011, 18:44 »
Those tyre pressures are fine, hope you get it sorted soon.
MK5 2005 GTI, BLACK, 3 DR, 18" MONZA II, XENONS
Offline am1w
« Reply #3 on: 04 January 2011, 18:46 »
Steve: A bit on the low side. Should be 2.6 bar or 37.7 psi. (1 bar = 14.5 psi).
« Reply #4 on: 04 January 2011, 18:50 »
Just done a quick VCDS scan and have the following fault code.
Address 44: Steering Assist        Labels: 1Kx-909-14x.lbl
   Part No: 1K0 909 144 H
   Component: EPS_ZFLS Kl. 74     2901
   Revision: 00H15000
   Shop #: WSC 01357 011 00200
   VCID: 2F661C5EC776
1 Fault Found:
00668 - Supply Voltage Terminal 30
            002 - Lower Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 13477 km
                    Time Indication: 0
                    Date: 2017.14.11
                    Time: 00:00:04
             Freeze Frame:
                    Battery Volts: 7.4 V
                        PD
                    Temperature: 12.0°C
                    Torque: 0.000 Nm
                    Torque: 0.0 Nm
                    RPM: 0 /min
                    Drive Current: 0.0 A
« Reply #5 on: 04 January 2011, 18:50 »
Thanks Asker, will change them to the correct pressure's
Offline R32UK
« Reply #6 on: 04 January 2011, 18:52 »
yeah of course they are mate  :rolleyes:
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #7 on: 04 January 2011, 19:37 »
Quote
00668 - Supply Voltage Terminal 30: Signal Outside Specifications
00668 - Supply Voltage Terminal 30: Implausible Signal
Possible Causes
Fuse(s) faulty
Wiring/Connectors from/to Control Module faulty
Power Supply (Battery/Generator) faulty
Possible Solutions
Check Fuse(s)
Check/Repair Wiring/Connectors from/to Control Module
Check Power Supply (Battery/Generator)
Special Notes
When found in an individual control module, it's most likely a local source (e.g. wiring/connectors).
When found in multiple control modules at the same time, it's most likely a common source (e.g. ground spot, battery, generator).
Intermittent codes are often stored during low outside temperature when the battery capacity goes down and may be ignored.
In other words prob the flat battery.
But the date and time :huh:
« Last Edit: 04 January 2011, 19:39 by Snoopy »
Current Garage:
35+ years of GTI ownership.
« Reply #8 on: 04 January 2011, 21:09 »
Quote
Possible Causes
Fuse(s) faulty
Possible Solutions
Check Fuse(s)
Special Notes
Why would the flat battery cause power steering problems?
And also do you think it's just a case of clearing the fault or has it caused some damage when the car was jump started?
Offline am1w
« Reply #9 on: 04 January 2011, 21:20 »
Quote
Possible Causes
Fuse(s) faulty
Possible Solutions
Check Fuse(s)
Special Notes
I had so many error codes when they disconnected my battery at the bodyshop sometime ago. Now that you mention your weighty steering, I felt mine was also very heavy after the diconnection took place. Darren attended to this.
Now, I seem to have a slighty weighty steering again, since the car has been to the bodyshop. They have promised me they had not disconnected the battery. :rolleyes:
PS: Also found idling was not as smooth.
« Last Edit: 04 January 2011, 21:36 by am1w »
