Author Topic: Alternator noise  (Read 2036 times)
Offline greggyboy
Alternator noise
« on: 03 January 2011, 21:39 »
Hi, got a whinning coming from the alternator area of the engine. The VW garage said it was the alternator, so i replaced it, which has improved the lights alot which is great but the noise is still there.
Any ideas as to what the noise could be, alternator belt or cam belt. Alternator belt is fairly new and the cam belt should of been replaced as it was serviced at VW until about 90,000 miles.
Regards
Greg.
Offline Neo Badness
  • Feet are for pedals
Re: Alternator noise
« Reply #1 on: 03 January 2011, 21:58 »
could be the belt is slightly misaligned? Is it an 8v or 16v?
Edit, meant to say when was the water pump changed last as you mentioned cambelt
« Last Edit: 03 January 2011, 22:00 by Neo Badness »
Offline greggyboy
« Reply #2 on: 03 January 2011, 21:59 »
16v 1.6 driver, which belt?
Offline Neo Badness
« Reply #3 on: 03 January 2011, 22:01 »
16v Driver? surely and 8v Driver? Mk2 golf?
Offline greggyboy
« Reply #4 on: 03 January 2011, 22:02 »
1991 mk2 1.6 driver
Offline Neo Badness
« Reply #5 on: 03 January 2011, 22:31 »
1991 mk2 1.6 driver
Ok, defo an 8v then. When was the waterpump last changed? Have you ever tried the mechanics stethascope trick?
« Reply #6 on: 03 January 2011, 23:14 »
Could be the cam belt tensioner or belt too tight.
